GR86 Carlinkit Android tablet box upgrade for head unit
Not updated to support split screen yet, it's app specific.
Works on mine... 🤔
Post in thread 'Carsifi Wireless Adaptor via Kickstarter' https://www.gr-zoo.com/threads/carsifi-wireless-adaptor-via-kickstarter.378/post-45788
I'm still getting the Bluetooth disconnect errors with carsifi, as that link is between the headunit and the phone I don't think anything short of a firmware update is going to fix it..
I might change my resolution back on my AAWireless if that is the case thanks for that Gari.
What phone do you have? Mine went spit screen start of last week (hardwired)
Pixel 7 Pro. That's the kicker, I've got Google's own phone so thought I'd be first for updates, but I guess not!
This is using wireless though (Carsifi) but I'm not sure that matters.
Not to rub salt in the wound but I have a Pixel 6... :ROFLMAO:
The OH finally paired her phone (an old realme similar to mine, nothing posh!) yesterday and it went straight to split screen.
The magic button works a treat to swap between phones (y)
I love the higher resolution, get more on the screen like that. You don't prefer it like that?
You do get more on screen, but I also feel like some of the buttons are smaller and a therefore a tad harder to press sometimes.
I only really changed the resolution (Carsifi) so it would force split screen, but I think the Coolwalk update enables that anyway. So when that comes, I will probably reset the resolution too.
So I've reset my dpi back to OEM and it does have splitscreen now, you need to toggle it with the layout button in the bottom right.
I agree with both points above that the 103dpi gives more screen but the buttons sometimes can't be hit first time.
I'll try OEM for a bit and see but glad they've sorted it so it's more like the Carplay layout.
Not had a problem with the buttons on mine.
Can you get the new split screen, but with the higher resolution? I'm guessing not... 🤔
Found that normal OEM Res is way more responsive but everything is massive argh !
Can anyone talk to the downside of the carsifi?
What don't you like, what's a bit rubbish?
My experience of multiple Bluetooth devices in a car is that they are frustrating, for instance are you connected to the radio and carsifi?
What happens when you get a phone call?
Once it's finished detecting your phone, then connected via WiFi to your phone, and your phone connects to the car via Bluetooth. So you can send and receive calls fine - just the same as when it's plugged in.
A couple of times it's failed to connect properly, but that seems to be my phone (5-year old Huawei P20 Pro), and switching off WiFi and Bluetooth and then switching it on again on my phone sorts it.
It's meant to support multiple phones, but not tried that, so can't say if that works or not.
It can take up to a minute to connect (usually does it on 10 seconds) when I leave the house, but think that's because my phone and car are connected to my home WiFi and it confuses things.
