GR86 Fuel cap cover alignment
Gari
Northamptonshire
Has anyone else got a wonky fuel cap cover? Mine sticks out towards the bottom and I'm not sure there's any way to adjust it o_O
Same here - slightly misaligned.
Doesn't really bother me but I am slightly worried of it getting ripped off at high speed.
I would take it back to the dealer to look at. I've had this with my wife's car - was fine when new, and became slightly protruding over a period of months. The dealer will have a way of adjusting I assume.
That isn't right, mine is flush with the body.
When the car goes in for it's recall I'll get them to have a look if I haven't sussed it out.
In the meanwhile I've had a good nosey behind the cover and can't see how adjustment would be possible. Hoping there are fixings accessible from inside the car that'll allow for some movement.
Mine is flush and as expected - looks like there is a potential quality control issue if a number of them aren't right.
Hopefully the dealer can rectify to your satisfaction.
Mine is flush too! Even if it was normal needs sorting!
Mine is also not smooth with the bodywork but not as bad as the first photo, I enquired about it but there is No adjustment to it. The dealer checked with toyota whom instead checked 3 other cars and none were smooth.
They said I could ask for a replacement but it will likely be the same, anyone inquired about this?
I went digging around behind the interior trim in the boot to find very little access to the assembly. It looks like it's installed by just pushing it in to the car's shell. Really not sure what the dealerships can do about this one...
I have just pushed mine flush with small amount of force. Seems to be better and staying for now.
Mine is very slightly out of alignment but you wouldnโ€™t know, unless you were looking for it.
It's going to get yanked open and slammed shut hundreds if not thousands of times in your stewardship. Unless it's massively out of whack, probably best to file under 'not worth worrying about'.
I did the same - it's seems to be flush now.
If I was to describe how much pressure to apply, I would say a reasonable amount but not too much that it feels you might break something. Best to do it whilst the car is locked so the door doesn't pop open.
