GR Yaris Boost control
Bigredzed
Does it only make full boost at wide open throttle. I can get mine to the redline making no boost unless I put the pedal right down.
On my turbo bike as soon as it reached about 4000rpm the lcd boost gauge would fly to full boost and you’d have to hang on.
Is my gr boost controller a bit lazy?
I've noticed occasionally similar behaviour - when accelerating gently towards full WOT boost seems to be lower from time to time. In summer it eas easier to notice, during winter I haven't noticed it that much.
Boost will vary according to throttle position. More throttle equals more boost and vice-versa.
boost is also temperature dependant the colder ambient temp is the less boost it'll take to achieve same power as when ambient is warm or hot
Ok, so a temperature related factor is that of the air in the atmosphere, probably with reference to the air density as well.
Related to temperature again, boost is limited during start up.
Based on @Mintmansam 's post, even after start up, full boost may not be available solely due to temperature. Please share any practical advice, especially on:
  • the figure of that temperature threshold
  • whether that is oil or water temperature
  • if it's water temperature, if/how we can monitor it while driving
Many thanks!
Many thanks!
The limiter is linked with the warning “warning do not use excessive acceleration while….” Once that goes it all good. Otherwise I think it limits boost to 1bar? This is only when below operating temp
the initial cold start warning is based on oil temperature as water temp comes up quite quickly much faster than oil
I thought the opposite is true, ie the initial warning goes away once the water hits the minimum suitable temperature.
As you mention, this is quicker to heat up than the oil. So, even after the warning goes away, I keep my eyes on the oil temperature in the dash until it hits circa 70 degrees.
(With no relevance to boost, the only other thing I try to remember is that the gearbox oil is even slower to get to temperature.)
0.2 bar, apparently.
