What tyres would you change to??PS4 tyre whine/drone which is slowly driving me insane. Although that just leads me to trying to kill the tyres even faster...
Oh great thanks, well worth a try! Which size foam did you use?Yep exactly the same! Fixed both with some CC sticky back foam. Couple on either side of the glove box panel and then the speaker panel and A pillar cover. It all pops off easy enough, the clips holding the pillar cover on are flimsy and are tethered as part of the side curtain airbag is behind it so its designed to pop off easily. Mine is now rattle free from that part. There's still a rattle in the rear and annoying PS4 tyre whine/drone which is slowly driving me insane. Although that just leads me to trying to kill the tyres even faster... according to my Toyota health check yesterday 2.5mm gone after 1200 miles so far assuming they came with 8mm....
Not to sure at the moment, Goodyear AS6 would be at the top of the list. I'd be tempted to try a 225 40 18 but in theory that generates more noise.What tyres would you change to??
I used 10mm as that's what I had lying around, works fine but 6mm would probably be best. The glovebox has a proper clunk to it now when you open it.Oh great thanks, well worth a try! Which size foam did you use?
PS4 come 7.3mm new..Although that just leads me to trying to kill the tyres even faster... according to my Toyota health check yesterday 2.5mm gone after 1200 miles so far assuming they came with 8mm....
Like this? https://www.ebay.co.uk/itm/22535828...dJr4P8QJc5vef9YOI6vWMeR10=|tkp:Bk9SR4Tr2IK9YQI used 10mm as that's what I had lying around, works fine but 6mm would probably be best. The glovebox has a proper clunk to it now when you open it.
This one - https://www.ebay.co.uk/itm/283015328771?hash=item41e5073403:g:yNgAAOSwm4NbKSTo&amdata=enc:AQAHAAAA4MtwVZlKGllicLTnDFezyqGyBPYf48Y+Qc+ZSotgOpyFI/oJNAOB7UagV323d+TSi33l9IMc+g5+ymRqhaPib8/cfFrY+dAMhh6V1rBkBG2WnoyC2sWUhS8lN0Sp6MEQRiDEiar1jggUO+DnBSWDWhLw5YzEL1NxZOObmvqh9EeX4tsMWhng7WbXHGVsZt7CIQ8rUNC28XactRUypWth2EYQsrYS6XSc7w9QOA/3w5XEgz1Xea/e3MVzLhmjzV4ayoF3txRbK2Vsfixx/fq18stzzDTi/PtpPbOl/8vp796g|tkp:BFBMsOSJg71h
Two points from me:
1. I've only noticed very minor creaks a couple of times on really cold days before the cabin has reached a pleasant temperature.
2. @PVGR , respect to you for the thread title; I don't think you have received the commensurate credit!
Had exactly the same on mine; I found (eventually) that it was the plastic A pillar that was creaking rather than the vents, and that it stopped if I put my finger between the dashboard and the pillar.Yeah mine is exactly the same, once the cabin is warmed up my creaks go away. But I believe for me they're coming from the left and right air vents.
When in doubt, give it a clout!Add me to the creaky air vent/pillar list. I think I've sorted it by whacking the a pillar.
