Having driven the car for about 750 miles now, I can't help to notice some details of the manual gearbox. This is my first manual car, and so please correct me if some of these are common. I have only driven a manual Fiesta before this. There is already another thread about the quirky clutch, so I will keep this thread only about the gearbox.
The gear shift knob is quite a good size and the shift feel is precise and tactile. However, in first gear at higher RPMs, I noticed the gear shift knob wobbles front and back a little bit. You can feel it more if you put your hand on the knob. This doesn't seem to occur in other gears. When driving off in the cold car, the second gear can feel difficult to shift into. When shifting to third, there can be a slight play felt in the powertrain as you engage the gear. Fourth, fifth, and sixth gear feel fine, but I can't help wishing the sixth gear could be a bit taller for lower engine RPM at cruise. Driving at 70mph, the engine RPM is about 4000RPM in fifth, and about 3000RPM in sixth. Luckily my commute is mostly on 50mph roads, which yields around 34.6mpg for me.
Also, when parked on a slope, it can be difficult sometimes to engage first or reverse. Consequently, I might have to put it into first when the slope is downhill and vice versa.
Do you agree with my observations? Would you have some more of your own?
