GR86 Dealing with scratches
Gari
Northamptonshire
Somehow managed to get three scratches just above the fuel cap. These kind of things are inevitable, but it still sucks.
What would you do to fix it, if anything?
They are fixable if you learn to build the paint up in many layers just in the scratch with a pin alowing each layer to dry properly or it will pull out again. Spring/summer is best and 3-4 days between layers. When dry fine wet and dry paper - around 2000 to rub it back being brave the first time as a patch of cloudy paint is left and your heart sinks. Then polisher and cutting/polishing compound to get it back to a shine and hopefully hardly noticable. It takes time and practice. I got an old wing from a scrappers years ago to get confidence. Used it a lot on the celica as that was a chip magnet on the nose. Managed to wait till it was about 10 before a respray for that section.
This is why I don't spend thousands on PPF
We got wife’s Prius done professionally. We got a quite for all major scratches. They were all sorted at the same time. I’d not trust myself do a pro job to be honest
Can you feel them with your finger nail? If not they should just polish out.
If you can then you'd need to do something like @cuddles suggests.
That’s not going to work, when paint top coat / colour has clearly been taken off as in the picture.
If you scratch the clear coat you often get a white residue that can make it look like it’s gone through, so maybe ok, even if you can get a thumb nail in it, it is sometimes ok. I’ve got some pretty deep scratches out in the past with 2000 grit sandpaper, then polish after. I bought a paint depth gauge so I can estimate how much to sand and still be safe.
