GR Yaris Cartek Shift Light and Gear Position Indicator
bigred
Hi all,
I wasn't sure if this was better in Interior or electrical, so apologies if I've lumped it in the wrong place :)
I really want a shift light for when I go out on track in the next couple of months, and I do really like the look of the canchecked vent gauge, but I'm not sure I've got the confidence to install it. With that in mind, I've spotted a couple of cartek ones (links below) which appear to install straight in to the OBD2 port with no additional wiring. They look like they'll do just the job I'm looking for, with minimal install required. Has anyone had any experience of running either of these or anything similar on a GR Yaris?
https://www.demon-tweeks.com/uk/cartek-shift-light-2013762/
Hi bigred,
We were discussing this on a WhatsApp forum and some have gone down the Pro Torque route and we found these that are good value plug and play options.
yes i went down the route of the lufi gauge (prior to the cancheck being available) and a hell of a lot cheaper (£68). It allows a shift light if required but not really in line of sight.
Ooooh, I really like the look of that. Is power taken from the OBD2 port then i.e. no other wiring is required? I'm assuming the big benefit with the Canchecked unit is that it comes with a specific vent fascia? Do you know if there is anything else the Cancheck unit does that the Lufi doesn't?
Hi bigred,
We were discussing this on a WhatsApp forum and some have gone down the Pro Torque route and we found these that are good value plug and play options.View attachment 12007
Those are really well priced. I've just responded to Eltel21 on the Lufi X1, but do the other Lufi units all connect straight in to the OBD with no other wiring required?
Hi
With Canchecked you can customise upto 10 screens and the main one that most want is Diff temps.
yes all power taken from the obd port, don’t know about the cancheck product but the shift lights on my lufi (x1) are built in.
I have it fitted. It runs off the obd port. It only displays gear number when the clutch is lifted and sometimes displays the wrong gear when going for it and hanging onto the revs through corners.
Shift light works great and really helps.
It also looks very rally car so I love it 😀
View attachment 13910I have it fitted. It runs off the obd port. It only displays gear number when the clutch is lifted and sometimes displays the wrong gear when going for it and hanging onto the revs through corners.
That looks quite cool!
Indeed it is, photo from a previous life 2s to launch.
I'm running a CANChecked unit with a custom page I created with a progressive "Shift Light" Bar and other into on it just enough for me.
Hi Nathan-el,
That custom page looks perfect. Would you be willing to share it as an exported file plus any associated .BMP files?
Many thanks!
Hi Nathan-el,
Many thanks!
Happy to share it. It's just a widget file made it with no .BMP files unless you want the start animation.
I've made it quite complex as I didn't know another way to do it. Happy to explain it all and even make small changes for you.
PM me and I can send you the file.
