GR86 Android Auto Bluetooth Disconnect Errors
SmokingPancakes
Warwickshire
Hello all!
When I'm driving along with android auto on, every now and then I get an error stating something along the lines, of bluetooth has disconnected, please check your android auto device. But after a few seconds the error clears automatically. Does anyone else get this issue? I tried to get a picture with engine off but not would not reoccur of course! :ROFLMAO:
I'm using a brand new cable as my old one would fully disconnect android auto and restart it when it was lightly shaken over a bump. New cable has solved that issue but still have the bluetooth disconnect issue.
Anyone worked out what could cause this issue or how to solve it?
Make sure you've updated your phone software and apps.
I was getting the error about system date/time is incorrect and kept getting disconnected. However a new cable seems to have fixed this. 2 hour round trip today and all good. Oh and I set the setting for clock to use phone date and time.
Had no issues so far with my Galaxy S10. Been completely stable....
same issue here, pixel 7 fully up to date and car software up to date. I'm going to try a different cable as sometime android auto goes into a restart loop that drives me nuts.
... but as my contract is due for renewal, I have actually just opted to upgrade to a Pixel 7. Bugger.
No issues on a pixel 6 pro so far but 2 friends are having these issues in other marques. Maybe a wider AA problem?
TBH I’ve never had a problem hooking iPhones to Apple Car play in several different cars , but the CEO had an Android phone at one company she worked for and it was APITA in various cars , hard to set up and totally unreliable connectivity 🤷‍♂️
I had Android Auto disconnecting and immediately reconnecting several times on my first long trip. I took the cable out, blew the contact points, reconnected and it's only done it once since and that was after going over a bump. It seems the wired connection is very sensitive. I'm going to look at putting something in the armrest to stop the phone from moving and possible get an angled connector.
I think I've found another option:
All my apps and phone are up to date, using a z fold 3.
Will give the contacts a good clean and use the other usb port and see if there's any improvement.
With this sort of thing I would go by recommendation. I have been stung quite badly buying a Chinese carplay adaptor for my wife's car
Yeah that's why I used Amazon. I've bought a couple of those adapters before for Mercedes and Mini and they've both been excellent tbf.
At least with this I don't have to take the dash off to send it back!
Did you buy a new cable or one you had around. I have a Samsung S10 and had it disconnected 5 times in a 2 hour drive. That and getting water splash from trucks was the worst thing of my driving.
Any recommended cables? I normally buy ones frome ebay
I'm trying to post a link but it's not working. Go to Amazon and search for Ankar usb a to usb c cable and that should give you some options.
So, it llo
Cheers, link worked. I will try that instead of the carsifi as it seems the later is around £100gbp
So, it llo
£75 delivered at the moment 😉
... and also gives the option for a higher resolution android auto then the software for the infotainment screen natively allows.
