The place to post all things related to the GR86 clutch pedal , questions, answers, modifications etc
It's a shame. I get the impression that some of the improvements on the GR86 were a direct consequence of some criticisms raised about the GT86, and this was quite a common one. You'd think that as they took the trouble to improve the gearbox with better synchros, that's they'd also just switch out the clutch spring for a slightly lighter one. I'm going to guess it's a marketing thing where they want to make the manual more accessible by decreasing the pedal force.
Still. At least it's easily rectifiable. For RHD vehicles, you need to take out the clutch pedal and do it on a bench, but it's not particularly difficult. I did it, and I'm an idiot. Good how-to below:
Please do! I'd like something as close to the MTEC as possible, as it's a known quantity, but you're right, £32 for a spring is a bit much.I've been doing a bit of research on clutch springs recently and I have found other options than just the MTEC. These springs I have found are between £5 and £7 each as opposed to £32 that MTEC charge! They are also available in various spring rates giving you more options! The only downside is delivery is £12, I can bulk buy and distribute for cheaper but that needs some interest first.
The stock spring is rated to about 150lb/in, the MTEC is 65lb/in so about 57% weaker than stock. The options on the table rate between 85% and 58% weaker than stock. I will update this with info and supplier soon.
I'd definitely be keen tooI've been doing a bit of research on clutch springs recently and I have found other options than just the MTEC. These springs I have found are between £5 and £7 each as opposed to £32 that MTEC charge! They are also available in various spring rates giving you more options! The only downside is delivery is £12, I can bulk buy and distribute for cheaper but that needs some interest first.
They are @ZN8 , problem is you have too many pedalsGreat choice Andy. I love Iron rangers in R&T copper, they are next on my list. My first pair of Redwings are these Irish setter Moc toes. No good for driving though.
