GR Yaris Stop-start and lane keeping
Boost Creep
Absorbed member
Hi All,
a bit of a weird one,
When my circuit pack car arrived, it seems to have the start-top disabled and lane departure (it still beeps) but is also off.
VIN 21778
After a lot of reading, I was expecting to have to instal an aftermarket work around to solve this. Have I missed something?
by default they should be on. If you got a car delivered by Toyota that has them off, I'd congratulate. maybe just document and cofirm with the dealer that it's ok in terms of inspection etc. As a product car would be better without those systems.
I think it depends on the settings? My lane departure just beeps in the normal mode but if I turn on lane centering it does a bit of fighting.
With the start stop, what modes are you using, and are you actually releasing the clutch?
I've seen both these systems do things in my car but 95% of the time I have it turned off. Honestly if someone would make a module to set the 4wd mode, start stop, imt, turn off the lane assist and press back on my steering wheel to dismiss the warning
Hi All,
VIN 21778
Your driving in normal or track mode and the s/s is disabled?
Might not be enough charge in the battery for it to operate, but the car indicates this. If you're in sport mode, the auto s/s is disabled.
As for the lane departure, I think it only beeps by default and a press of the button puts it into active lane assist.
Hi All,
VIN 21778
Could be a software update. Yours is a pretty recent build. Maybe they’ve been listening to us moan 😂
Hi All,
VIN 21778
Is the stop-start light on the dash illuminated by default?
Be interesting if this is a software update.
I've fitted the module that turns off lane departure on start up and suspect that if the software is updated then the module will switch it back on :-)
I'd be happy if the stop-start didn't work! 😂 😁 (y)
OK, I think I might have jumped the jump with optimism; it either kicked in when I activated the connected app, or it's down to driving style.
I tend to keep the clutch depressed when stopped or at the light, and I think that blocks the stop-start. I also tend to indicate when changing lanes which overrides the lane keeper. ?
Yep that's how it is on both counts. The problem with the LTA is that I drive down a lot of urban roads for work and when you have to go round park cars I don't of course indicate. This is why I turn it off. I only turn it on to use it on the motorway when I'm in active cruise on occasion.
Lane assist only works fully with cruise control activated. That's when it pushes you back in lane and tracks the car in front.
Err... tracking the car in front is part of the cruise control function. Pushing you back into lane is Lane Trace Assist which works independently of the cruise function.
Or at least it does on mine
Agreed - lane trace assist works independently of cruise control (which I haven't used in the GR Yaris).
I tried it out for the first time the other weekend. I like the radar cruise and the lane assist, but I pretty much always use indicators on the motorway
The systems on the GR are pretty crap anyway. Auto high-beam, lane keeping, radar cruise. All ropey to a degree.
iMT is the one redeeming “auto” feature, it rarely puts a foot wrong, unlike the others.
