GR Yaris Post your Best Updates for the GR so far!
Michael Knight
Finland
Post your best updates to this thread!
Mine have been so far (90105-17013) Camber bolts and wheel alignment 120€ in total.
Spiced up the cars handling - now the steering feel is much better (was bit numb initially) and front axle gained quite a bit more traction in corners. Front has now -2.2 camber and 0.14 degree total toe out.
Funny it took over 6months to get this done. Kind of made the car reborn again as it gained another level in terms of performance and handling.
The Yaris is certainly very receptive to it and it make a really positive difference. I kept increasing it and feel -3 is the sweet spot for normal use.
Couldn‘t agree more.
Camber and a bit of toe out is one of the main things this car needs to be the best it can be.
Define 'normal use'? :p
I did 3 and at least on our nordic winters it was great fun - downhill cloverleaf drift just on throttle, but really it was too lively at high speed. I've heard opposite things on trackday tyres.
So might be two set-ups are needed. If one can set toe oneself, and with full articulation on OE bolts, a 30min job or so.
Mine GR has now lighter rear from the LW battery + this more aggressive front end has transformed car quite a bit on sport mode, tad too lively rear to be honest. Maybe on dry asphalt it will be just perfect. As the turn in is now improved it will be a blast to shoot off from the apex!
Given the setup was off from what it should be could ask if Toyota want's to compensate (as car should be in the specced values as delivered) but maybe should have done right when received it.. .
A Mirror Riser!! - So worth it. No more ducking to look under it at junctions and bends. Seems like the new Yaris Cross needs one too from the Carwow review! 😅
You’re all wrong.
haha I have that cup holder and I use it all the time lol :LOL: :)
Reactions: MrJ
Not really an impressive modification, but I never used Rain-X on a car before, but tried it here in an attempt to keep the rear glass clear. That stuff really does work!
I use that stuff after every wash. They sell it in a big spray bottle now. Works like a charm. It actually stops the windscreen frosting up too.
Mine is clicking the rear seatbelts in.
I would also do the passenger seatbelt but it makes me feel lonely.
funny done that on mine as well
I did this in the earlier days to keep the warning message away but now the seats have been flat for months as I have a full length boot mat so I can't plug them in now! :confused: 😅
have you noticed if this has creased your seats at all?
