GR Yaris Camber Bolts
burrellbloke
Absorbed member
I have been doing some reading but I am new here so I am sorry if this question has been answered elsewhere already.
I have come from owning Renault Sports were camber was difficult to get without expensive modifications like coilovers or aftermarket adjustable top mounts.
Can I achieve something like -2.5 or -3 degrees of negative camber with camber bolts on the front and rear hubs? If so can someone give me either the Toyota OEM part numbers and a link to buy what I need?
Or, are aftermarket products considered to be superior, if so can someone suggest where I can buy the parts?
I've put Powerflex camber bolts, but the guy doing the geo said he can't get more than -2deg20min on front (-2.33), have -2.0 rear
you also got this video showing camber bolts
I've got the Powerflex camber bolts. Does the job under £25 or less on the occasional ebay sale.
But reports saying if you track often you may need to geo it again to make sure it's still right.
powerflex are infinitely adjustable, Toyota are fix amount
easy neg 2.5⁰ but might struggle get neg 3⁰ with powerflex but close
I got Toyota 90105-17015 bolts and ended with exactly -2.50° both sides after alignment. As far rear goes I'm not sure if you can add camber in other way than getting adjustable control arms or lowering rear.
I have the powerflex ones too, got my geo rechecked after some work at Toyota and after 8 track days mine were exactly where I'd left them a year ago
I have put paint blobs and tick marks on mine. If the paint bead breaks then something has moved and mine haven’t
Mine didnt move either (front and rear camber bolts) and I have 1500+ track kilometers...
I only heard of camber moving with thinner toyota bolts?
Yeah the washer type ones really shouldn’t move as the tooth takes up the 2mm smaller diameter so the bolt holes on the upright and strut shouldn’t slide apart
