GR Yaris Random low tyre pressure warning light on rear tyres
Bat out of Hell
Bedfordshire
Hi, I'm getting the warning light come on, but only the rears, it has only started happening as we've moved into cooler weather.
Has anyone else had this issue
Cheers
Cheers
I had this last winter and again on cold days recently. Tyres are down a few PSI vs default and the alarm comes on, when the tyres heat up the alarm usually goes off. I’ve put a few more PSI in the tyres and that solved it. I’ll adjust it down again when it warms up.
I work nights and occasionally get a low pressure warning when I start the car to go home. After checking motorbike tyres every time I use it I’m used to it changing with temp etc quite often
Yeah, got that. The calibration on the TPMS system seems very sensitive and/or it doesn't have ambient temperature offset built-in. I've never had any other TPMS system do this.
Mine started doing it about 2w ago. After about 20 mins it sometimes goes off, sometimes doesn’t despite displaying 2.0 bar which is recommended pressure??
Also to note the temp gauge measures in 2 decimal places but only displays one so it rounds up or down depending on the value which is why you might get a tyre showing red but the display showing the correct pressure.
