Bronson
I'm bored of using ramps and I'm sure there has been threads on these before on the other site, has anyone got suggestions for a low profile trolley jack?
That looks familiarYeh the central jacking point on the GRY is about 800mm from the sills. I’ve just bought this from Demon Tweeks as the long reach jacks have either a chassis that’s too high or they are several hundred pounds for a 1100mm Jack.
https://www.demon-tweeks.com/uk/sealey-trolley-jack-2-tonne-low-entry-1020le-sea1020le/
My GRY is lowered, sills are about 155 off the floor, jacking point is 100mm, so hopefully this Jack will work (chassis 125mm)
Damn it, could have saved myself £20.That looks familiar
Halfords 2 Tonne Low Profile Hydraulic Trolley Jack | Halfords UK
Shop the latest Halfords 2 Tonne Low Profile Hydraulic Trolley Jack at Halfords UKwww.halfords.com
A vehicle lift is the only way except I don’t have the garage space for one yet.You're going to struggle to get one under the front jacking point. I have an arcan jack from costco, really well built and has done me proud for over 10 years. But I got annoyed jacking mine up and splashed out on a set of these
For what it’s worth, I have this one and need to drive one wheel a couple of inches up a ramp to get it to the front central jacking point. Rear is fine:
Halfords Advanced 1.5 Tonne Aluminium Trolley Jack | Halfords UK
Shop the latest Halfords Advanced 1.5 Tonne Aluminium Trolley Jack benefits from a quick-lifting mechanism at Halfords UKwww.halfords.com
Really nice little jack, and the GR is the heaviest thing it has to lift.
Me neitherA vehicle lift is the only way except I don’t have the garage space for one yet.
No, it's not designed to be bolted down, you couldn't push the car along on it. It's never moved at all for me. It'd be like trying to push more than a full IBC along. I guess there's a max safe gradient that it's designed for but I didn't look at that bit of the instructions, my drives pretty flat.@Matt it's really cool, but I'd be worried about the lift moving if it wasn't bolted down, no issues then?
They must think we all own wrc rally long jacks.Just had this exact problem tonight - what a ball ache. As you say, even a low profile jack won’t get very far under from the front and I don’t own ramps or anything similar. In the end I just went round the side jacking points changing the wheels one by one which added a bit of time but at least it’s done now.
Will be next on my shopping list. It’s funny as my mechanical skills are pretty much limited to only changing wheels and I now have lots of bits and pieces for basically one job, when I could’ve just taken them with me when it got serviced anyway. I suppose it’ll all come in handy at some point in the future.I’ve got some low profile plastic ramps, drive the car onto those then a normal jack slides Under
