GR Yaris World premiere of GR GT3 Concept and fully tuned model of the GR Yaris
I think they've done a decent job of this, because judging by the reactions I've seen and my own thoughts, it hasn't really spoiled the ownership of the standard cars.
The icing on the cake would be if Toyota made all the add-on parts officially available across the world though.
Its good to note that Toyota claims different service requirements and warranty for GRMN. Traslating directly with google translate (from precautions before purchase).
Quite a bit different than what Toyota 10yr extended is at the moment.
Sorry fo mess..
Please note that GRMN Yaris has a different warranty period from other Toyota cars. * 1 Item Items Items to note Category Item Items Items to note Category General Drive system Chassis vehicle Interior 1 Maintenance Manual transmission, Differential (new car 1000km Oil change while driving) Inspection and manual transmission oil in GR garage when traveling 1,000km, rear Change the differential oil. (Manual transmission, rear differential It is recommended to perform inspection and replacement in the GR garage. The replacement cost will be borne by the customer. 2 Maintenance Manual transmission, Rear differential Use the specified oil (compatible with mechanical LSD). 3 Maintenance Rear differential The oil change cycle should be every 5,000km. 5 Precautions Reinforced clutch We are using a metal clutch. Depending on how the clutch is engaged when starting, Vibration (judder) / abnormal noise (squeal) may occur, but this is not a malfunction. Rapid operation (rapid clutch engagement) until the condition of the friction surface stabilizes (about 500 km in the city) Please drive while avoiding driving at full throttle. 4 Precautions When replacing the flywheel clutch, if there is a lot of wear, it may be replaced at the same time. 6 Precautions Transfer 5000km break-in is recommended. (Driving avoiding sudden acceleration and deceleration) 7 Precautions Tires Since the tires are specialized for exercise performance, they may wear quickly. 8 Precautions Tires have a dry grip priority design. When it rains, slow down sufficiently and try to drive safely. 9 Precautions important point Tires The gap between the tires and the body is narrow and the chain cannot be attached. 11 Precautions Do not adjust the height of the shock absorber. It is not covered by the warranty. (It is assembled to the vehicle after adjusting to the optimum condition) 10 Aluminum wheels The aluminum wheels in the circuit package are matte painted. May be glossy Therefore, clean it only with a neutral detergent, and avoid using wax or cleaners. 12 Precautions Since the minimum ground clearance is low below the vehicle, avoid using a mechanical parking lot or stopping from the front. 13 Maintenance Steering wheel If you experience the shine that is peculiar to the suede skin, spray it with water. 14 Maintenance Parking Brake Lever If you experience the shine that is peculiar to the suede skin, spray it with water. 15 Care Shift Lever Knob If you experience a shine that is peculiar to the suede epidermis, spray it with water. 16 Attention Front pillar garnish, Defroster garnish Due to the flocked coating, there is a risk of leaving marks if touched. Please handle with care 17 Precautions RECARO Seat height, angle, and seat belt adjustment require tools, so please consult your dealer. 18 Care RECARO Sheet If you experience the shine that is peculiar to the suede skin, wipe it with water. 19 Precautions RECARO sheet Aged deterioration may cause wrinkles, shine, etc. 20 Precautions Rear seat (without seat) Not designed as a luggage storage area. Please do not carry luggage / people. 21 Attention Center outlet (When the optional center cluster is installed) The air conditioner wind from the center part is difficult to reach the head. 22 Precautions Carbon bonnet (CFRP) Due to the characteristics of the material, you may see swells and shades of the twill pattern. There is no quality problem. Also, if you are exposed to ultraviolet rays for a long time, the color may change. We recommend storing it in a place that is not exposed to the sun. Due to the characteristics of the material, you may see swells and shades of the twill pattern. There is no quality problem. Also, if you are exposed to ultraviolet rays for a long time, the color may change. We recommend storing it in a place that is not exposed to the sun. Due to the characteristics of the material, you may see swells and shades of the twill pattern. There is no quality problem. Also, if you are exposed to ultraviolet rays for a long time, the color may change. We recommend storing it in a place that is not exposed to the sun. Please refrain from using the car wash machine as the GT wing may get caught. 23 Attention Carbon roof (CFRP) 24 Precautions Rear spoiler (CFRP) 25 Precautions Matte gray paint Do not use wax containing alkaline or abrasives as it may cause gloss. Guarantee 26 Warranty Front Differential 27 Warranty Rear Differential 28 Warranty clutch (cover / disc / release cylinder simultaneous replacement) 29 Warranty shock absorber 30 Warranty steering wheel * 2 31 Warranty parking brake lever * 2 32 Warranty shift lever knob * 2 33 Warranty Front Spoiler 34 Warranty Side Mudguard * 3 One year from the date of new car registration. However, even within that period, he has a mileage of up to 20,000km. Exterior
The reality of performance driving $$$ and time too...
ill get the bonnet and the wing ... otherwise i love the torsen diffs and how they work on a road and even on a track,
The seats are the same/similar to ones i have in other cars.
I think the GRMN is fantastic .
But it just makes me love my GR more !
I'm only really interested in the rally suspension. Even so, I'm good and will just continue enjoy driving my now cheap as chips rally homologation special as it is :p
Yes I'm after Tactive magnetic or GR Rally spec set if I ever get rich enough. Maybe the former as I like the option to change settings on fly when driving to the track (via gravel roads etc) - makes the already versatile supercar even more versatile..
I like the bonnet
If this was same price as the circuit pack, I’d only seriously option the bonnet. As this is the daily driver.
Circuit / Rally lovers it’s perfect.
Can you imagine the PPF, underseal crew having a mild panic when it rains with that bonnet “anyone covered the bonnet hole with clear vinyl” 🤣😂
I love that it’s available and if anyone gets one, seriously nice work, just for god sake enjoy it and don’t use it as an investment!
I presume either longer 1st gear and closer stack on the first lay shaft or alternative final drive shaft ratio but this would give a large hole between 3rd and 4th.
That has been available for ages. 4k ish
I like the bonnet
Wonder if it'll have a longer 2nd gear for better 0-62mph numbers ;)
Uk have snapped up as many as Toyota can give us and more, why wouldn’t they consider supplying the UK and rest of the world with some editions , this time they would be making some money on them
Yeah it is a shame. It says Japan only! :confused: (n)
Love the steering wheel in alcantera. Looks like it has a smaler rear view mirror also.
That's exactly how I want my steering wheel to look when it's sent off. No need for the GRMN then!
I like the wheels, the genuine carbon roof and the seats, but that's about it.
No power increase, so no hope of an approved Toyota map for the standard car.
