Its good to note that Toyota claims different service requirements and warranty for GRMN. Traslating directly with google translate (from precautions before purchase).
Quite a bit different than what Toyota 10yr extended is at the moment.
Sorry fo mess..
Please note that GRMN Yaris has a different warranty period from other Toyota cars. * 1 Item Items Items to note Category Item Items Items to note Category General Drive system Chassis vehicle Interior 1 Maintenance Manual transmission, Differential (new car 1000km Oil change while driving) Inspection and manual transmission oil in GR garage when traveling 1,000km, rear Change the differential oil. (Manual transmission, rear differential It is recommended to perform inspection and replacement in the GR garage. The replacement cost will be borne by the customer. 2 Maintenance Manual transmission, Rear differential Use the specified oil (compatible with mechanical LSD). 3 Maintenance Rear differential The oil change cycle should be every 5,000km. 5 Precautions Reinforced clutch We are using a metal clutch. Depending on how the clutch is engaged when starting, Vibration (judder) / abnormal noise (squeal) may occur, but this is not a malfunction. Rapid operation (rapid clutch engagement) until the condition of the friction surface stabilizes (about 500 km in the city) Please drive while avoiding driving at full throttle. 4 Precautions When replacing the flywheel clutch, if there is a lot of wear, it may be replaced at the same time. 6 Precautions Transfer 5000km break-in is recommended. (Driving avoiding sudden acceleration and deceleration) 7 Precautions Tires Since the tires are specialized for exercise performance, they may wear quickly. 8 Precautions Tires have a dry grip priority design. When it rains, slow down sufficiently and try to drive safely. 9 Precautions important point Tires The gap between the tires and the body is narrow and the chain cannot be attached. 11 Precautions Do not adjust the height of the shock absorber. It is not covered by the warranty. (It is assembled to the vehicle after adjusting to the optimum condition) 10 Aluminum wheels The aluminum wheels in the circuit package are matte painted. May be glossy Therefore, clean it only with a neutral detergent, and avoid using wax or cleaners. 12 Precautions Since the minimum ground clearance is low below the vehicle, avoid using a mechanical parking lot or stopping from the front. 13 Maintenance Steering wheel If you experience the shine that is peculiar to the suede skin, spray it with water. 14 Maintenance Parking Brake Lever If you experience the shine that is peculiar to the suede skin, spray it with water. 15 Care Shift Lever Knob If you experience a shine that is peculiar to the suede epidermis, spray it with water. 16 Attention Front pillar garnish, Defroster garnish Due to the flocked coating, there is a risk of leaving marks if touched. Please handle with care 17 Precautions RECARO Seat height, angle, and seat belt adjustment require tools, so please consult your dealer. 18 Care RECARO Sheet If you experience the shine that is peculiar to the suede skin, wipe it with water. 19 Precautions RECARO sheet Aged deterioration may cause wrinkles, shine, etc. 20 Precautions Rear seat (without seat) Not designed as a luggage storage area. Please do not carry luggage / people. 21 Attention Center outlet (When the optional center cluster is installed) The air conditioner wind from the center part is difficult to reach the head. 22 Precautions Carbon bonnet (CFRP) Due to the characteristics of the material, you may see swells and shades of the twill pattern. There is no quality problem. Also, if you are exposed to ultraviolet rays for a long time, the color may change. We recommend storing it in a place that is not exposed to the sun. Due to the characteristics of the material, you may see swells and shades of the twill pattern. There is no quality problem. Also, if you are exposed to ultraviolet rays for a long time, the color may change. We recommend storing it in a place that is not exposed to the sun. Due to the characteristics of the material, you may see swells and shades of the twill pattern. There is no quality problem. Also, if you are exposed to ultraviolet rays for a long time, the color may change. We recommend storing it in a place that is not exposed to the sun. Please refrain from using the car wash machine as the GT wing may get caught. 23 Attention Carbon roof (CFRP) 24 Precautions Rear spoiler (CFRP) 25 Precautions Matte gray paint Do not use wax containing alkaline or abrasives as it may cause gloss. Guarantee 26 Warranty Front Differential 27 Warranty Rear Differential 28 Warranty clutch (cover / disc / release cylinder simultaneous replacement) 29 Warranty shock absorber 30 Warranty steering wheel * 2 31 Warranty parking brake lever * 2 32 Warranty shift lever knob * 2 33 Warranty Front Spoiler 34 Warranty Side Mudguard * 3 One year from the date of new car registration. However, even within that period, he has a mileage of up to 20,000km. Exterior
