GR Yaris Suggestion for those with Carista/OBD11/Techstream..
Sly
Devoted member
Morning!
An idea I saw on another forum - can we not sticky this post and those with Carista/OBD11/Techstream, and willing to help other members, post where they are located and if anyone needs to do a small tweak on their car, they could potentially reach out to that member and swing a few £££ to the owner of the device?
Could be useful for example - I want to enable wireless AA on the wifes Seat but I don't want to fork out for a Carista/OBD11 just to change a setting from OFF to ON for example :D I'd rather swing someone who owns the dongle £10 or something for the ability to change a single option..
this is now a sticky
good idea as could do with a few tweeks to mine (y):eek::whistle:
Curious - what tweaks do you want to do?
I'm around Doncaster if anyone has a Carista/OBD11 they don't mind meeting up so I can make a tweak to the Mrs Arona please :)
For those needing - I've ordered a Carista dongle and got the app.
I'm in South Yorkshire if anyone needs a hand :)
I have Carista and a dongle. South Manchester. I would add though that you can simply pop to your dealer and they can do the same for you with turning things on and off.
I’ve got Carista and the beta app, not a subscription. If it’s still working I’ll have it with me at Castle Howard 👍
I heard some dealers can be sticklers for those sorts of things?
Same - will bring mine with just in case anyone needs a hand. I'll be walking around with a baby in toe and a camera in hand - look for the tall(ish) South African :ROFLMAO:
Hi Laure,out of interest what sort of functions can be turned on or off?
thanks
steve
thanks
steve
From the Carista website:​
Chassis & Engine​
Active Noise Cancellation (ANC)​
On / Off
Engine Sound Enhancement (ESE)​
On / Off
Dings & Warnings​
Seat belt warning ding (driver)​
Enabled / Disabled
Seat belt warning ding (front passenger)​
Enabled / Disabled
Seat belt warning ding (rear right passenger)​
Enabled / Disabled
Seat belt warning ding (rear left passenger)​
Enabled / Disabled
Driver Assist​
Default distance for Pre-Collision System (PCS) alarm when the PCS switch is turned off and back on​
Normal / Remember last distance
Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch off​
Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch on​
Instruments: Displays & Nav​
Display odometer after ignition is turned off for…​
30 seconds / 1 minute / 10 minutes / Off
Microphone sensitivity​
1 - 11
Instruments: Heads-Up Display (HUD)​
Image distortion in heads-up display (HUD)​
Concave high / Concave medium / Concave low / Default / Convex low / Convex medium / Convex high
Image keystone in heads-up display (HUD)​
Narrow bottom high / Narrow bottom medium / Narrow bottom low / Default / Narrow top low / Narrow top medium / Narrow top high
Image tilt in heads-up display (HUD)​
Anti-clockwise high / Anti-clockwise medium / Anti-clockwise low / Default / Clockwise low / Clockwise medium / Clockwise high
Lights: Exterior​
Lane-change turn signal auto-flasher count​
Off / 3 flashes / 4 flashes / 5 flashes / 6 flashes / 7 flashes
Turn signal click volume​
Low / Medium / High
Lights: Interior​
Turn on interior lights when you shut off engine​
Yes / No
Parking Sensors​
Parking sensor beep volume​
Low / Medium / High
Activate parking sensors in neutral (N)​
Yes / No
Front corner parking sensor range​
Short / Long
Rear center parking sensor range​
Short / Long
Windows & Sunroof​
Open windows and sunroof via long-press on remote​
On / Off
Close windows and sunroof via long-press on remote​
On / Off
Open windows and sunroof by turning and holding key in door lock​
On / Off
Close windows and sunroof by turning and holding key in door lock​
On / Off
Open driver's window using single button press​
Yes / No
Close driver's window using single button press​
Yes / No
Open passenger's window using single button press​
Yes / No
Close passenger's window using single button press​
Yes / No
Passenger window single-touch-open from driver's switch​
Yes / No
Passenger window single-touch-close from driver's switch​
Yes / No
Wipers & Washer​
Automatic wipers (using rain sensor)​
Yes / No"
Thanks Lauren 👍
The reality is, not that much. It's of pretty limited use really. Though I get you can configure more if you have a convenience pack car. I've played around with the ESE and ANC, though ended up leaving both on. I've got the window single button press so I can open or close the windows from the fob. Note opening the windows on the fob is of limited use because you will set the alarm off once it re-arms if you don't open a door within 30 seconds. I never use this function.
Being able to close the windows on a single button press is moderately more useful, though perhaps ever so slightly so. I've used this at least 3 times in the last year.
I've turned off the beeps for seat belts, but as I never drive without a seat belt, this option is of limited use as a result.
Carista is great if you have an EML and you want to clear the code, but I admit, I've not had an EML for nearly a year now! So, yeah, incredibly limited use. Is it worth buying one and paying the £58 yearly subscription? Not really. 😭
So my Carista didn't do what I needed on the Mrs Seat Arona, I've ordered an OBDeleven if anyone needs a hand with one of those.
Aberdeenshire - Carista dongle due in tomorrow.
Also have VAGCOM, Multiecuscan (Fiat, Alfa), an Autel dingus, and software for Nissan Elgrande (Speaks Consul). Seem to attract odd diagnostic jobs!
  • Wow
Reactions: Sly
If anyone has one in South Wales, please let me know! Just want ANC / ESE turning off
... I've not had an EML for nearly a year now! ...
I'm under the impression that you don't have a sports cat/downpipe/decat installed, so why would you have an EML?
I recall you posting about having an aftermarket exhaust fitted, but any GPF/OPF-back exhaust alone shouldn't trigger an EML, should it?
