GR Yaris Vehicle Data Logging
SJR202
Woking, Surrey
Hi
Cant see this posted elsewhere, sorry if wrong - had a quick look in the manual kindly posted on this forum and saw this about data and video logging - anyone know if that is installed in the UK market GRY or know anything else about it? Given they'd hand over the data if required to govt/police it seems a bit worrying the car might be tracking everything you do to be used against you?
The vehicle is equipped with sophisticated computers that will record certain data, such as: • Engine speed/Electric motor speed (traction motor speed) • Accelerator status • Brake status • Vehicle speed • Operation status of the driving assist systems • Images from the cameras Your vehicle is equipped with cameras. Contact any authorized Toyota retailer or Toyota authorized repairer, or any reliable repairer for the location of recording cameras. The recorded data varies according to the vehicle grade level, options and destinations with which it is equipped. These computers do not record conversations or sounds, and only record images outside of the vehicle in certain situations. z Data usage Toyota may use the data recorded in this computer to diagnose malfunctions, conduct research and development, and improve quality. Toyota will not disclose the recorded data to a third party except: • With the consent of the vehicle owner or with the consent of the lessee if the vehicle is leased • In response to an official request by the police, a court of law or a government agency • For use by Toyota in a lawsuit • For research purposes where the data is not tied to a specific vehicle or vehicle owner z Recorded image information can be erased by any authorized Toyota retailer or Toyota authorized repairer, or any reliable repairer. The image recording function can be disabled. However, if the function is disabled, data from when the system operates will not be availa
UK cars almost certainly come with such systems. I mean, look around you, there's surveillance everywhere.
If you look at the car from the outside, at the upper part of the windscreen, at the centre, I believe is a forward-facing camera.
I assume data isn't tracked about "everything" you do and will be made available in rather extreme circumstances only, ie major accidents, etc. In those cases, such data from your car, as well as any other cars involved, may be used to protect your interests, not just against you.
In the secret/hidden menu you can switch off logging.
I assume this would switch a lot of this off and dovetails with what is said about the dealer being able to switch on/off and delete data etc as those options are there.
Secret menu is accessed with info from this: https://www.gr-yaris.co.uk/forum/threads/hidden-menus.2876/
Remove this from behind the dash and no more tracking....
It will also help you call emergency services automatically if case of a crash, and help you locate your car if it was 'misplaced', by yourself (it happens more often then you think) or by 'others'...
If you switch it off, it means you also switch of your smartphone?? Same thing (but worse...)
I'm pretty certain that's just the rain sensor
So, no camera there? Not even for the lane assist?
Thats really interesting thanks. So I feel like a cynic now, 99% of its use is for technicians to check systems, maybe if a fault is found with a car they can track it to something but like with any data held by any system, if the police/authorities want to access it then they can, so maybe in a severe crash the GRY will be able to show speed before/during an impact etc or inputs from a driver.
Depends on your market I guess? In the Aussie market there is no Toyota app to talk to the car so im not sure how an owner would 'find' a misplaced car... and AFAIK no provision for the car to call the emergency services in an 'event'.
If you switch logging off using the hidden menu your smartphone still works... unless im not reading what you wrote correctly?
Don't know, what I wrote was blatantly Euro-centric, didn't even know you (AUS;NZ;JP?) had any logging...
In the EU area, or at least in the the UK, TSS comes with a laser / camera / radar to pick up a number of hazards/speed limit signs/pedestrians/driver falling asleep and drifting etc. This is also model dependent. The camera / laser sit in the middle of the windscreen at the top. I would assume it also works like a plane's black box in the event of an accident - but it is all about preventing one hence the low insurance premium with a functioning TSS. A bit of frost over the top of the windscreen in winter and the whole thing stops functioning - in summer it works overtime. :)
https://www.toyota-europe.com/world-of-toyota/safety/toyota-safety-sense
