KobayashiMaru86
Not sure of the full story as I'm relying on translation but seems sealant from somewhere got into the engine. Similar happened to some GT86s that had the recall too.
Another one. For me when it comes to engine mods is the first 2 years that are key. If nothing happens within that period then I'll be happy to modify.
View attachment 6045View attachment 6046
I'm not sure they'd be able to tell, would they? I'm thinking of doing a 1K change myself as it's quick and easy to do. As long as you use a branded OEM filter and sump plug washer I'd doubt they'd be any the wiser.At least it confirms that it's wise to do an oil change at 1000 miles. You could do it yourself to be sure but I'm not sure how that goes with warranty. The dealer could do it but then you'd never see the contents of the old oil. But if you do it and find an issue, how do you stand then? If it's on stick and obvious that better but if the oil is full of bits, unless you do it you'll never see it.
Pic above is the oil dipstick damaged?
It's not part of the schedule, no. But if the break in period is 1000 miles, then it seems like it would be sensible to just change the oil after that period, as that's when most wear is going to have occurred. I could do it on the drive easily in about 15 minutes, so for a brand new car that I intend to keep for a long time, it wouldn't be much skin off my nose for a bit of peace of mind that I'm doing the best of the engine's longevity. Perhaps I've just been watching too much M539 Restorations on YouTubePic above is the oil dipstick damaged?
Is a 1k oil change part of the service schedule or just something you want to do yourself for peace of mind?
From reading my warranty doc from another manufacturer all servicing to maintain warranty needs to be carried out by either an approved dealer (Land Rover in this case), or a VAT registered garage using only genuine Land Rover parts etc etc.
Doing it yourself on the drive I suspect would give the warranty company (if not Toyota an underwriter) wiggle room to get out of payment. All service records will be on the central database. For the sake of a few hundred pounds on a brand new car with potential of 10 year warranty I'll give it to Toyota to do this one![]()
Ahh I see. I was thinking more of just doing it as a precaution. I wasn't even sure just an oil change would find the problem mentioned, unless some of the fragments came out with the oil.I think it's more an issue if you do find something. How do you explain what you found and how you found it without the challenge of 'was it an approved garage that did your oil change?'
You'd like to think it wouldn't be an issue as Toyota UK are typically relaxed compared to other marques and other markets but you never know.
You obviously weren't very good at building them thenI used to build engines a few years ago for a well-known supercar brand, who's entry level fare was worth an easy 5x what the GR86 was - their engine recall rate was in the double figure %s.
fair pointYou obviously weren't very good at building them then![]()
Ah, makes complete senseIt's not part of the schedule, no. But if the break in period is 1000 miles, then it seems like it would be sensible to just change the oil after that period, as that's when most wear is going to have occurred. I could do it on the drive easily in about 15 minutes, so for a brand new car that I intend to keep for a long time, it wouldn't be much skin off my nose for a bit of peace of mind that I'm doing the best of the engine's longevity. Perhaps I've just been watching too much M539 Restorations on YouTube
I'm still not sure there's any risk to the warranty. Yes, the warranty is only valid if you ensure you meet the service schedule requirements, but an additional oil change (with genuine parts) would exceed those requirements. But as I probably wouldn't bother documenting it anyway, it seems a moot point - it's just for my own benefit.
