GR86 GR86 Brake upgrade Poll
Are you planning on any brake upgrades
  • 1. No - should be happy with OEM
    Votes: 26 40.6%
  • 2. Yes - OEM calipers , Aftermarket pads / discs
    Votes: 15 23.4%
  • 3 . Yes - Aftermarket Front Brake kit
    Votes: 5 7.8%
  • 4. Yes - Aftermarket Front and rear Brake kit
    Votes: 10 15.6%
  • 5. Undecided
    Votes: 8 12.5%
  • Total voters
    64
AndyRC
East Yorkshire
@Will300 has put together a great thread on the brake upgrade options available for the GR86 using his experience and knowledge of the GT86, currently a work in progress.
It will be interesting to know who is planning to upgrade the brakes on their GR86. A few of us are already eyeing up the TRD GR Monoblock kit and GT86 Brembo Performance Pack as it provides matching rear callipers too.
Have a vote and share your thoughts πŸ‘
In stages for me so pads, fluid and lines on stock setup as I know how good it is and great on the roads. If I get more serious and do a few track days then I'll look at getting a full AP setup.
Leaving it stock to begin with, but would consider upgrading down the line if I track regularly.
Lol I've already started, still undecided what I'm doing for the fronts.
Before anyone asks, they were cheap for the current market, which I why I bought the rears before the fronts.
I can now see why you describe them as β€œdiamond shape” πŸ‘πŸ˜Ž
Found a photo of them in red
My rears will be going off to be painted next month now I know they will fit. Fronts will be coming off the GT86 next month too. I'll give them a birthday ready for when the new car comes.
Just my two cents: Managed to reach 86000km with the first set of GT86 brake pads (including some track days on the NΓΌrburgring and Bilster Berg). Reason enough for me to assume I don't have to change brake system parts on the GT86, time will tell...
Bye for now. Fred
Found this on a US forum , IMO caliper painted red with the GR sticker looks OK but the standard discs with 18s look as though the CEO put them in the washer on a β€œHot Wash” and they have shrunk 😳, plus she put a red tee shirt in as well πŸ˜‚πŸ˜‚πŸ˜‚
i will go with the front calipers from the 07 WRX...
In the US are people running it and it seems to be okay...
Proably going with a set of MX72-Plus as a dual duty set of pads and any higher temp fluids.
Already finding the stock pads too soft under braking and cooked them already on road. Maybe it's the fluids not the pads but not chancing it.
Lets hope they hold up with occational track day.
My local dealer had a new GRY next to where I was sat , couldn’t help a little bit of brake β€œdrooling” πŸ€ͺ
The GR86 TRD kit has slightly smaller front discs but larger rear discs and would look 😍
Where did you get the paint? I was thinking red against EB would look good, then I had a look on ECP and they have 2 very similar blues that might be a match for EB (https://www.eurocarparts.com/caliper-paint) but if they don't quite match then it will look a bit jarring like someone has not matched the paint correctly, so it might look better with a contrast rather than a paint that is a couple of shades out.πŸ€”
Not quite a mechanical upgrade but definitely an aesthetic one. Quite therapeutic way to spend a spring like weekend. Can't believe how poor the factory calipers look on a brand new car.
Well done! That does give it a good lift actually!
