GR86 Patty Boi
Prestonese
Dedicated member
London
Ok ok. It's not your typical reviewer but I thought it was a more of a real world test than others. Some helpful insights around how it's tricky to drive smoothly when going fast, a similar flaw as the GT86 - i.e. caused by the clutch delay valve and helper springs. Anyone with links on how to address those issues would be most appreciated!
Ok ok. It's not your typical reviewer but I thought it was a more of a real world test than others and he gave some helpful insights especially around how it's tricky to drive it smoothly when going fast caused by similar flaws as the GT86 - i.e. the clutch delay valve and helper springs. Anyone with links to address those issues would be most appreciated!
I’ve got a solution to both of those problems , but at the risk of causing a riot I’ll keep it to myself 🤣
Ignore Americans. That's my solution. Sure, you can take the valve out like you could also do in early M cars but having driven a Z4M and a first gen GT86 spiritedly on the road it's not much of an issue
I had a Z4M and my experience was the same as your. I didn't bother with removing the CDV. That said, my experience of driving the GT86 was that the clutch was a bit trickier to get used to. I guess we will need that test drive after all....
When we got my brothers 86 I drove it home from Oxford, found it fine. When he drove it for the first time he was having issues because he was rushing the shifts. He's come from a Swift Sport which responded well to be driven however you wanted. The 86 you have to be far more precise. To get him to think more I got him to take a breath between shifts, especially when going quickly and go from there. Now a few years in his shifts are quick and he's a far better driver than he was. The 86 is a car that trains it's driver. It forces you to drive properly. In hot hatches you can get away with murder.
Seems odd no other reviews have mentioned this.......
