GR86 GR86 Infotainment
AndyRC
East Yorkshire
Everything Iโ€™ve seen so far talks about an 8inch infotainment screen
BUT if also seen this in official Toyota releases.
This bigger screen looks much better IMO๐Ÿ‘ all I want in any car these days is Apple Car Play and would pay extra for that screen.
Hmmmmmm
Unfortunately I very much doubt you will see that coming to Europe, I saw the same and went digging for it.
The 9" display you see is a T-Connect NSZT-Y68T and is offered as an option on the GR86 in Japan. The only information I can find on it is all Japanese, there is literally no english for it. I think its domestic only.
@ZN8 Thanks for the info ๐Ÿ‘ , if you have any links You could post that would be appreciated, @kinboshi is pretty good at getting the relevant info out of Japanese sites.
it will be a shame if we couldnโ€™t get that display in the U.K. , even if itโ€™s an aftermarket unit , I only want Apple car play these days
Andy
Apple car play is included in the factory head unit so there will be no need to change if that's all you are after. I've attached the link below, scroll down to accessories and you will see it there.
link
link
Thanks for the link , this looks like it ๐Ÿ‘ it was the bigger display that I liked the look of , is SmartLink the same as Apple\Android Car Play ๐Ÿค”
That's exactly what it is. Just an alternative.
If that unit isnโ€™t available via the Toyota dealerships Iโ€™m sure someone like Fennsport will be able to get hold of them , the BIG question will be how much ๐Ÿค” It just looks so much better IMO and as I always have Waze on the bigger the screen the better for me.
If Iโ€™ve put the correct numbers in Google thatโ€™s looking like ยฃ1550 , plus shipping etc ๐Ÿ˜ณ so may be a bit too pricey for me โ˜น๏ธ
It would appear that the GR86 is designed to accept a 2-Din, Double Din, head unit. Someone posted this video on a US forum of a Pioneer unit being fitted to a GR86 in Japan. It looks a very good fit in the opening and has on OEM look . I believe similar units are available in the U.K. Most owners will probably be happy with the standard fitment head unit and controls. If youโ€™re interested in a larger unit this may be a good starting point.
Another 2-din unit, this one has less of an OEM look but does show the installation process pretty well
@ZN8 , You were right with your initial thoughts. ๐Ÿ‘ Having checked with a well know importer of Japanese parts the headunit is only avialiable via Toyota dealerships in Japan. As it appears to be a double Din unit, the Pioneer head unit looks the most viable option at the moment. Iโ€™m sure once the GR86 arrives some of the audio specialist will be able to offer options ๐Ÿค”
Wow, thatโ€™s a fair bit more of work compared to swapping out the GT86 unit. That takes 10 mins.
I currently have a nice pioneer head unit so might hang onto it once I swap the original unit back into the GT86 to see how I get on with the OEM on in the GR.
I expect the connect 2 unit required will be the same as the steering controls look the same as the facelift 86.
I am going to do the same. I have a pioneer and expect the connections will be the same even down to the usb adapter.
Did you get your GR yet and attempt the swap out?
Hmmmmmm
nice screen but too many blank steering wheel buttons for me
So i accidently hit the radio button for the first time. Now whenever i get in the car and am waiting for Android auto to connect and take over i have to listen to the radio, HAVE TO..
Am I missing something simple? I don't want to be adjusting the volume everytime I'm in and out.
What you could try is select aux first, then connect phone. Then it should remember aux was before AA so defaults to that. With nothing plugged in it's quiet
That sounds like it should work, honestly been driving me nuts. Thankyou
