GR Yaris Judder when accelerating from 2krpm
Michael Knight
Finland
Noticed that car has occasional judder when accelerating from lower rpms, lets say 2-2.5krpm.
This was apparent when car was new, then it disappeared after few thousand miles. Now after installing HJS seems like it got back.
Not sure if it is due to improved turbo spool and added torque to low rpm's, incrased exhaust harmonics/resonance, fw related issue or what.
It can be certainly felt in some instances in the seat so not purely sound related. Funny though it goes away occasionally.
Most prone if driving with 4th gear in low speed (40-50km/h).
As people running with tuning boxes etc. find it hard to believe it would be fw related issue as there should not be much added torque for the driveline (mine car is stock).
~2k rpm is a fairly low speed to be accelerating from in a lightweight 3cylinder engine. Just drop down an extra gear, you could possibly damage the engine through LSPI if you put high load on the engine at low rpm.
According GR’s driving computer you should upshift in 2.2krpm..assuming there in LSPI issue gear change range maybe different
yes i have noticed this on the rare occasion. its not happy under load in lower revs.
Mine does a thud thud kinda noise but it isn’t a judder, full load at low revs is a someone above states LPSI territory, shouldn’t be done. I often will feed in the throttle. Never had a judder though.
How would you describe the throttle position before and during the judder? Can you give more details on the judder?
The upshift indicator isn’t fixed to a specific load or rpm, if you light on the throttle the car will encourage you to up shift, if you have a lot of load it may even suggest a downshift at 2.2k rpm
Mostly light to medium load - normal city driving
You have the correct grade oil? And are using 98ron fuel or greater?
I recall someone’s coil stick failed early on, perhaps it’s this?
Does it properly rock the car back and forth like a mis fire?
nope I feel that it is more of an NVH type of sound so maybe not driveline related. Maybe worth checking out the Engine support mount if there's something..
When driving fast this noise is cancelled so solution is to drive faster.
