GR86 First MOT, Modified Cars, Future Emission & Noise Issues
Sixtoe
Absorbed member
South East
My 2023 GR86 just had it's first MOT, and one of the advisories was;
"Catalyst Emissions Limit Only Just Met"
Mine is fitted with the GR airbox and a cobra un-resonated cat back exhaust.
I was quite surprised at the fact it was only just under the limit, I've not had it tuned after running those things so could that be an issue? (and does that mean I have to spring for the whole ecutek thing?)
Also, this is... worrying? if anyone is looking to maybe play with mods in future;
https://www.evo.co.uk/news/209071/c...with-uks-tuned-and-modified-vehicles-targeted
This is also interested considering a lot of mods seem to want to remove the cat;
https://www.evo.co.uk/news/206327/g...-down-on-loud-car-exhausts-not-just-emissions
Be interested to see what anyone else thinks, I was thinking of turbocharging mine at some point, but now I'm wondering if this hasn't harpooned that...
I have the same mods as you: Cobra Non-Res and TRD Cold Air Intake. There is no requirement to tune with either of these. Nothing was picked up at my MOT for emissions in March of this year when it went into the dealership, maybe take it somewhere else?
The new regulations will likely restrict a lot of 'dodgy' mods, especially as it could lead to the keeper being prosecuted in certain areas like emission system tampering (which was always illegal anyway).
Do you occasionally give it the beans? I was always trying to get the best MPG I could while commuting but gave her the old Italian tune up more often in the lead up to my first MOT. I've kept up the habit! If the revs aren't getting high enough often enough I believe carbon deposits can build up which negatively affects emissions .
That's interesting, I got it done at somewhere quite a way away as I was on my way somewhere else and it'd been sitting on the motorway cruising for an hour...
An hour on the motorway wouldn't be enough to result in any significant build up, it would be constant motorway cruising at low revs over months. I was so focused on getting an average 35mpg according to the car on my commute, hit the target and since I've dropped it to 34.1mpg 😂
The GR intake does move the position of the MAF, so it will impact AFR, its how some air intakes claim to make more power, not because they are better flowing but because they lean out the AFR, but in this case it shouldn't be by much, definitely not enough to alter the emissions that much, the short and long term fuel trims would take care of that.
Catalytic converters are very sensitive to temperature, maybe it just wasn't that hot when they did the emissions test?
ruled over by joyless jobsworths sadly.
Proposed changes to emissions regs and testing are a concern in general given the potential for an older bone stock car to fail.
Fuel quality, atmospheric conditions, test method could all impact results. Owners like myself who intend to keep the car forever could find themselves unable to source OEM replacements for parts which fail entirely or sufficiently to not meet regs.
It’s an absolute can of worms for all older vehicles modified intentionally or otherwise. I’ve no doubt it’s as futile as trying to hold back the tide but I filled out the gov.uk consultation form disagreeing to all proposed changes and voicing the potential negative impact to the public and motor industry as a whole.
This is very interesting, Ensuring my car passes emissions tests is why I have been so specific with my front pipe selection and ended up getting one custom made and shipped from the US. I'm taking mine over to an old friend's garage to get emissions tested next week in leu of it's first MOT. He used to build the cars for a drift team and he's got some crazy Japanese cars, so I hope it comes back with tread on the rear tyres still :LOL:
Without wanting to sound like an unpaid advertiser for JDL, their turbo kits have a 400CPSI cat in the downpipe, so might end up being the best choice for the emissions conscious UK GR86-turboer. apparently they're RHD compatible.
That sounds really interesting, I'm wondering if it's going to force all UK tuners to do that as well anyway.
I'll be very interested to see how yours goes on the test :)
I’m starting to sway toward a JDL catted header. I’d wanted to stay EL as I’m not a fan of the “subie rumble” but it’s looking like trying to improve performance and not fall foul of emissions testing is a massive pain. Apparently the HKS carted EL header is good for a performance boost but not effective enough to keep emissions in check.
If losing the OPF coding it off and switching in a catted down pipe would work for an NA application I may look at going down that route.
I’m half expecting my Navara, with its combined DPF, EGR, AdBlue deletes and Stage 1 remap to maybe not get through its MOT after the new regulations kick in, but we’ll see. I’ve primed the wife that she might be getting a new petrol hybrid Pickup truck next year and funnily enough she’s quite happy! 🛻
I'd assumed any decat or DPF/GPF/Adblue deletes were already MOT failures "by the book", if the tester identifies their absence. Visual check so you can core delete them and pass with a shell assuming your welds are good. Depends how closely the testers look / friendly, etc. and ECU maps would be impossible to detect 'visually'.
My read of the consultation on this point is they're wishing to substantiate public opinion; that the current car regs already cover this, for vehicles that come stock with cats/DPFs.
Can or worms indeed, but would that mean a standalone ECU counts as "bypassing emissions equipment"?
An ECU is not emissions equipment in a direct sense in the way catalysts, OPF’s EGR’s etc are but replacing the standard unit or reprogramming it can impact emissions. It all gets a bit like F1 regs in as much as are you adhering to the explicit wording or “spirit” of the regs. No doubt interpretation could be impacted by the individual carrying out the testing and/or whether the changes are outwardly apparent from a visual inspection.
Is it possible to have it remapped with an OPF/GPF delete, then come MOT time shove the standard mid pipe back in, assuming the pipes are easy enough to reinstall and dont need removing.
Asking for a friend of course
It's strange that it passed so close to the limit. I don't think anything you have done should have realistically increased it. Maybe they tested it absolutely stone cold.
You could do that, but one of the key things that's people to fail to understand is that this is already illegal and would fall under a construction and use offence. You cannot modify a car to remove any emissions control system.
The difference is this is only really enforceable by the police, who don't really.
The DVSA are having a big crack down on garages and MOT providers as well as drivers, so the legislation here is basically trying to give them the powers to enforce it.
This has caused big waves in the biker community too as many choose to run without a cat at all in their exhaust , and motorcycles are exempt from any emissions testing which they are looking to remove also. It still wasn't legal just basically unenforced.
I dont think Id lose any sleep over it tbh. I know its illegal.
Lot's of effort every year for 3-4bhp gain.
