GR Yaris Rötheli Racing - crashed GR Project
Phil1291
Zookeeper
Staff member
Vendor
Sirnach, Switzerland
Sooo…
Some of you might have already seen it: I bought another GR — this time from a client who unfortunately had an accident on the Nürburgring Nordschleife. He crashed the car and caused quite a bit of expensive damage.
The insurance company declared it a total loss. Technically, it could be repaired, but the cost would exceed the car’s market value — and for what the repair would cost, he could simply buy a used, undamaged GR here in Switzerland.
Fortunately for me, I’ve got nearly everything I need left over from my race car:
  • Subframe
  • Suspension
  • Steering rack
  • Door
  • Lower wishbone
  • Brakes (calipers, discs)
  • Airbags
The only parts I had to buy were:
  • Fender
  • Driveshaft
  • Headlight
  • Wheel Bearing
  • Wheel Hub
The differential might also be damaged, but we won’t know for sure until the car is back together and ready for a test drive. If that’s the case, I’ll probably upgrade my race car with a 1.5-way diff and use its OEM one for this build.
The rear quarter will be repaired as best as possible — same for the front and rear fenders. I don’t mind a few scratches or small dents as long as they’re not too obvious.
We’ll also be using this project to try out new parts and work with a few partners we haven’t featured on the race car build — and of course, there will be more videos coming to YouTube.
Plus it will get a lot of leftover used parts from the race car.
Here’s the first one:
véhicule épave pour juste cela? Ca semble leger quand meme a l'oeil :incertain:
Soooo. Update:
Car is basically finished.
Just need to do a full alignment, replace the airbag and remove all the vinyl wrap adhesive, which is like 3kg or so, and we‘re done.
Today we installed a KW V4 Clubsport, our Oil Pan with baffle plates and our Set of Recaro Podium.
Love it. =)
@Phil1291 which size/brand seat belt buckle did you use for the Recaro Podiums seats? thanks
Nice.. can you share the link or the part re: adapter ?
Of course. But you might want to buy that locally…
