GR Yaris Ordering custom wheels - dilemma on offset.
MarkyMark
Absorbed member
I'm in the process of ordering some custom wheels and need to decide on the offset. I don't feel the need to go really wide, I would prefer the benefit of a lighter wheel than a wider tyre. I currently have the OEM circuit pack wheels, with 21mm spacers. The new wheels I'd like to do away with the spacers.
So with an 8.5" wide wheel, an offset of ET30 will give the same poke as 21mm spacers. However..... I think there is room for a little more poke, perhaps about 5mm. So I'm considering going for ET25
Any thoughts? Am I going to ruin the drive? With the existing 21mm spacers, its sublime, loving the car more than I ever thought I would. So sense tell me leave it as it is. But as I have the choice, if I can make it perfect from a visual point of view, with no detrimental impact, why not?
Any thoughts/opinions?
Anything under ET30 on a 8.5J wheel is going beyond function & into stance territory. Yes, it will look great under ET30 but you will certainly loose what the GRY is ultimately about in regard to handling for sure. Radius scrub, rubbing & overall handling is at risk here.
I would not go under ET 35 myself.
Remember you are going to be stuck with it once you change rim et.
Ok, some good advice and guidance there. I'll order ET30, that is the equivalent of the OEM wheel with a 21mm spacer which I have at the moment, and the drive is uncompromised/superb.
9j et38 is the perfect setup imho, sits flush, and gives option of 245/255 tyres
I think GR Corolla forged wheels are 8.5J and ET30 and look great on the Yaris with their slight concave vs standard.
I think you'll be fine. Just don't go 9.5 and ET35 as it will rub the rears... Ask me how I know 😭
Do you know the part numbers?
…Like the equivalent of ET23ish on a 8.5J. That’d need crazy tyre stretch to pull off. I’d definitely like to see a photo of that fitment though! 🤟
I have 225s on ET32 with 8.5J. The ‘poke’ is just about perfect and as the tyre centreline is just a negligible deviation from standard, no issue with geometry being out of whack and also the rolling radius is basically the same as standard so no speedo over/underread.
ET30 would basically be the same, but @Phil1291's handy lookup matrix doesn't go to ET25 so I'm not sure if that would create any issue with rubbing etc.
Well I thought they looked great! This was with 265 tyres and I think they weighed 8.6KG but can't find the photo now. These might have worked with 255 tyres or less but I'd rather some rim protection. The rubbing only happened on big suspension compression so thought I'd got away with it at first, until I got to the fun roads :(
So in the end I went with SL04 again but in 19x9.5 ET42 (9.4KG weight), which doesn't give as much concavity as the 18s but may even look better plus have a raised centre cap.. unfortunately they drive worse so I don't really use them on road:-
And yes, the garage door has now been painted 😄
I use Enkei RS05RR 18x9 ET40 (IIRC they weighed 8.7KG) with 245/40 tyres on the road and they drive great.
I should also add that I used my 19s ☝️ on the road for a couple of months and they drove fine too. A little uncomfortable with smaller sidewall but not too bad. I think you'd have to do something drastic to really ruin the ride.
I'm working on a custom sized GR BBS replacement. I think I should be able to have 18x9 made at the same weight as the 8" wide stock wheel. Goal would be to run 255/35 as they have the same diameter as stock. I think ET40 might be optimal.
