GR Yaris Brake vibration
Thanks, Yeahh new discs are ready to fit this weekend (when it stops raining!). There was some corrosion on the inner surface picked up at the most recent service, so should fix it. I’m a really light braker (tend to just lift off before a corner and coast round), so the rears don’t get much use.
Any tips for bedding in the rear pads would be great btw, is there an easy way to ensure they get hot enough rather than just the fronts taking most of it? I can only think of reversing 😂
My rears look perfect after 70k km.
I think driving like a t**t the way the car was intended to be driven is all that’s required.
Haha, yes definitely so. I am so used to being sympathetic and while it’s still a benefit, being a little firmer/positive on the brakes would be the way to go now. The drive is on an incline and pulling away after a few days, the rears have always had the most surface rust so suspect it’s a case of not clearing that effectively enough, so then by the end of a drive there’s a little left. That then seeds more for the next time and it’s a snowball effect.
FWIW when it’s wet I will try to use the brakes a bit more a few miles just before arriving home, get some heat into the discs before parking up, stop them flash rusting.
Even with that, I also leave it with the handbrake off when it’s damp to avoid the shoes sticking to the drums.
The handbrake doesn’t act on the calipers though so nobody should be worried about that.
