GR Yaris Whiteline front caster bushes
Provenjohn
Devon
Hi, In the instructions for the front lower arm caster bushes from whiteline it says to fit the stepped washer as follows:
# For best performance during acceleration place stepped washer above (on top) of bushing.# For best performance under heavy braking, place stepped washer below
Can anyone shed any light on the difference please?
These are the instructions: https://imageapi.partsdb.com.au/api...rTiO/6nZW08q1M4p8CcSO3EiSg/xqFg5JagZH4KOlYrKr
I'll be doing hillclimbs & sprints with the car
Thanks
by placing the washer up or down will slightly bring the geometry behaviour toward anti-lift or anti-dive. I cant back it with any data and WL does not provide a comparison either, but I think the differencies would be hardly noticable. I installed the washer on top and I never tried the setting with the washer down though. but the change compared to the stock (and super soft) bushing is definitely noticable and it was worth the hassle of changing the bushes. I think there was a thread alreay long time ago where the effects were discussed.
we measured the stock bushing vs whiteline and actually there was little difference between the setups for anti lift as stock bushing was already towards that.
so it depends on car how bushings are set up. I agree that stiffer bushing gives likely more change vs. few mm difference in geometry.
