GR Yaris GR Yaris Fog Light Upgrade
SasanSB
Germany
Hello everyone,
I've been having some drama with my GRY the past 6 months. I've had a LED Light bar patched into the circuit of my fog lights. When using the OEM fog lights, everything seems to work.
However my goal was to replace the fog lights work proper ones. To do so I've ordered the fog light housing from Veleno from Japan. They essentially allow for 3rd Party LEDs to be installed, which wasn't possible with the OEM LEDs. I've since tested both LEDs that I bought in Bali as well as Veleno's own LEDs which are marketed towards the GR Yaris from Japan. As soon as the aftermarket LEDs are plugged in, both the light bar as well as the fog lights do not work. They will switch on for a few seconds and then immediately turn back off.
Does anyone have any experience upgrading / modifying their fog lights? The lights I have are definitely not defective but they're also not playing nice with the car's electronics. I've also tried canbus adapters from Philips but nothing seems to work.
I'm considering having the fog lights be patched completely separately from the fog light wiring which would render the OEM fog light switch useless. But this could be problematic with our local TÜV upon closer inspection. The dealer now wants to try parallel wiring of both the new as well as the OEM fog lights to see if these can be added on top and if the car will then accept the signal... Even if this works though it's a crap solution as I'd be forced to leave the OEM housing hidden and installed behind the bumper...
Help. 🥹
I replaced mine with Diode Dynamics
I really liked IPF fog lights. Really easy to install, no wireing but you'll need to get housings too. Here's link to my quick video I made.
If you're interested I do have Ipf lights for sale.
I think I've come across your video in the past. I have a housing from Veleno which would be the same as the Prius or RAV4 housing you mentioned, but none of the LEDs I bought are plug and play even though their attachment seems to be that way as they are compatible. The car just switches the lights back off. I'm assuming you're controlling your lights with the twisting for light switch on the lever, right? This definitely doesn't work for my car.
Those look incredible, but how did you wire them? Do you have a separate switch installed to control them from inside the car? Are they directly hooked to the car battery or patched into the fog light wiring?
My Toyota dealer can't seem to get any aftermarket LEDs to work when they're patched into the fog light wiring. The car just switches the lights back off after a few seconds.
I'm considering having them wired separately with a switch being installed inside the car but that would render the fog light lever controls useless which might be problematic upon closer inspection when I need to get my TüV renewed in 2027.
They were Plug & play, done a bit of reserch beforehand, on these you can change the lenses obviously at a cost from yellow to white, from fog to spot to driving.
They are quite highly rated in the USA.
Search for diode dynamics online, they have new models out now.
How did you wire them? You're using the normal fog light switch on the lever to control them? Also, in what housing did you install them? Perhaps you could attach some close up photos.
Thanks
Hi SasanGB
Unfortunately i didn’t take any photo’s.
They operate off the normal fog light switch on the lever.
It was a simple swap with the original, the wiring harness comes with the lights.
I hope this helps
Hi SasanGB
I hope this helps
Do you have a part number please?
Almost forgot I did this as it was so long ago - I got Lexus CT200 (or Prius) fog light housings which allow use of other bulbs:-
81220-47010
81210-47010
And then some IPF yellow LEDs to go in them. Worked well with no messing about.
Are these bright enough to use them as low beam support? We have very dark roads here and the default low beam lights are way too dark for my taste.
Hi there, the lights looks fantastic. I enquired with DD and this was their reply.
The Question is I have a 2024 Gen 2 GR Yaris. May I know if SSC1 LED Fog Light Kit for 2023-2026 Toyota GR Corolla will fit the GR Yaris. Thank you..
The reply is Unfortunately, we have not yet confirmed foglight fitment for the GR Yaris, and this kit is unlikely to fit. .
Since they didn't have anything related to the GRY, I asked about the GRC. Which model did you purchase? A link would be most appreciated. Thanks
As the gen2 doesn't have foglights, I'm not surprised they don't have a kit for them!
As @Duke has said the gen 2 doesn’t have fogs
After quite a lot of research the fog lights of the gen 1 GR Yaris are the same as quite a few other Toyota models.
These are the ones i have SS3 LED SAE/DOT Type B Fog Light Kit Pro Fog Optic Yellow Diode Dynamics.
Hello everyone,
Help. 🥹
Hi I put
Toyota Prius fogs in , direct replacement dirt Cheap on eBay . Fitted with LED bulbs . Have excellent lateral spread . Also fitted an 18 Diode Dynamics 18 inch combo light bar behind grill.
