Bat out of Hell
Doing my 1st track day, I need to install the towing eye. I think I have to remove some trim ?. Any advice on safe removal would be much appreciated
I took your advice and managed to remove the panel without any damage. Let's hope my track experience today has the same results "no damage".Use a plastic trim removal tool. It's quite brutal to remove the panel, but don't be scared!
I didn't want to keep repeating the process, so I bought a Cusco towing eye and drilled the panel, so the body of the towing eye is permanently in situ, then at the track I then fit the eye.
I'm still alive, most importantly the car is fine and was faultless. I would highly recommend Bedford Aerodrome , very professional and the staff were brilliant.Stay safe !!
Just refitted the trim removed to allow fitting the towing eye. That was more stressful than my time on the track. Got all the lugs lined up and pressed it in , most clicked in place but a few refused to locate. Tried to encourage those last lugs in, but it didn't happen. So went for the only option available, a whack with my hand and bingo, all lugs located and no trim broken. I would imagine the plastic trim would cost more than my track day if it had broken .I took your advice and managed to remove the panel without any damage. Let's hope my track experience today has the same results "no damage".
