GR Yaris Battery cut off switch Q
matt-c-GR
Hi.
Anyone using a battery cut off switch?
I want to use one with my Lithium batttery, but wondering if i will then have trouble accessing the battery to switch it on again if c locking is off ?
There's a physical key in the key fob that can be used. It depends where you put the switch.
i was going to use one of those that connects on the battery post
There's no key opening for the boot, so you can't lock the boot unless you crawl back to the battery through one of the doors to hook up the battery up again
Unlocking the boot from inside is a fun thing to do, especially if you have a racecar with a full cage and race seats…
Can highly recommend it twice a week, so you can skip your Yoga Class.
Thanks Phil, another good argument for wifey why to put a cage in a car
