GR Yaris GR Yaris awd system - an explanation
Onehp
Svveden
Wrote this on PH and on another forum, took some time so thought I share/save it here too. Goes deeper than the quoted press pack and compares to other systems.
From the press pack:
“The full-time system is simple in design and light in weight – lighter than alternative twin- coupling or centre differential systems. Operation is electronically controlled with three modes the driver can select to suit their preference or the driving scenario. Slightly different gear ratios are used in the high-response coupling and rear differential, allowing greater drive force to be directed to the rear wheels even when there is no slip at the front wheels.
The mode options are: 50:50 Track mode, suitable for fast driving in any road conditions, from dry to snow; 30:70 Sport mode, to prioritise rear-wheel drive characteristics; and 60:40 Normal mode (the default mode), suitable for day-to-day performance.
The transfer case is constructed in aluminium and contains a hypoid gear, with bearing support optimised for rigidity. Lightweight aluminium is also used for the rear differential, which is integrated with an electronically controlled multi-plate clutch. The two units are connected by a three-joint, two-axis propeller shaft.
The system’s ECU controls the drive torque distribution to suit the driving situation, according to data gathered on vehicle performance such as speed, acceleration, braking and steering. Electronic control of the multi-plate clutch uses information from the wheel speed and G sensors and the clutch’s temperature sensor.
The GR Yaris Circuit Pack is additionally equipped with front and rear Torsen limited-slip differentials which offer enhanced cornering performance and grip with control of left and right-hand drive torque distribution on the front and rear axles.“
Awd systems is a rather big subject, and not very often I meet correct explanation on the workings as they often stop short, so I tend to dig deeper myself as I’m keen to understand what’s actually going on. This is that, I'll try to explain how the GFY system works in the light of other awd systems present on hot hatches and rally oriented road cars of the past. Brace yourselves, it is not very short…
First off, forget the idea that all awd systems ’distribute’ torque just like as one reads in marketing material. Torque distribution is instead induced by loss of grip of the other end (= ’passive’) or difference in rotation speed (='active’ or ’vectoring’).
Front rear power distribution.
The GR Yaris has a transverse engine, the gearbox directly drives the front differential. There is no center differential. Rear differential is driven also by a shaft directly on the gearbox, but with a multi-plate clutch in between. This clutch is a slippy clutch, so it can transfers varying amount of power back depending on the pressure on the clutchpack. Up to this point, this is the same layout as what is commonly referred to as ’Haldex’. Haldex isn’t as bad as it may seem as they are also electrically governed and can very much close the clutch before traction is lost in front. If the haldex clutch is fully closed, torque goes wherever there is grip, front (100:0) or rear (0:100), and everything inbetween depending on grip. It’s that simple. However, the system cannot ’choose’ all rear, but it can choose all front by opening the clutch. So character varies between fwd and ’locked center diff’. How well it works depending on calibration of the electronics that control the clutch, and the clutch reaction time.
With that straight, how can the GRY do 70% rear? As mentioned in the press release, by gearing the rear axle 1% higher. How so? When the ’Haldex’ style (but lighter) clutch is fully closed, with even grip front and rear, the rear will push more because it wants to go faster. But it can’t as they sit on the same car, instead the rear tyre slip increases and for the same grip level front and rear, that means more torque and power is put to the road to the rear. By smartly governing the center clutch slippage, it can thus choose, actively, to send approx 40/50/70% of the power to the rear actively even before there is grip loss anywhere. This is calibration work using calculated engine torque and calculated power transfer to the rear, a combo of clutch pressure, temp and difference in rotation speeds front/rear. Something like that. Smart and light.
The Focus RS and the A45 gen2 do something similar, overspeeding the rear axle, but instead of one clutch and a differential for the rear axle, they bin the differential and use one clutch for each rear wheel. Bit more on that later.
How about Evos and Subarus and proper Quattro (not Haldex)? These exist in many awd variations but key is that these have a center differential of sorts. Some use versions use viscous coupling or Torsen (more on Torsen later), and later versions are ’active’. The latter I wish to highlight especially as it’s easy to think they are superior to the GRY system. They are much more complicated mechanically. They use a symmetrical (50:50) or asymmetric (e.g. 40:60) center differential. An open differential absorbs speed difference between the outgoing axles, but the torque distribution towards each end remains the same always. Meaning that if one end spins loose because grip is zero, the other side not spinning has zero torque also. So the axle with lowest grip governs the amount of torque and therefore power that can be put to the road. Not so good. So while e.g. 40:60 is good with rear push, loss of grip on either axle reduces overal power put to the ground. The ’active’ part is then some form of locking mechanism. Mechanical (plated/torsen), electronic controlled clutch type or both. By locking, power goes where there is grip, as before. As such, the difference with Haldex isn’t as large as one might think, and the system cannot actively choose where to send power as many think is the case with sometimes active center differentials, it mitigates grip loss and is thus still passive in a sense. How the car behaves is also here governed by calibration of the locking system, and that part is adjustable on later Subarus (DCCD), the clincher being that a locked center differential causes understeer. Similar things apply to all above covered systems, locking front/rear causes understeer if the front loses grip (usually still travelling straight), and oversteer if the rear loses grip (in a curve). Both a result of the smaller circle the rear tracks with the front wheels turned which also creates a push between front and rear. Only the GRY/FRS can actively create this push already in a straight line, and thus have more potential to influence balance by actively governing power ditribution. And only the GRY is clear what distribution you choose/have. All the while being among the simplest and lightest. Downside, it might overheat esp with extra power. So while the adcance systems of e.g. Subaru or Quattro are good, the Yaris is right up there and a winner in my book.
Left-right power distribution
This is a matter both for turning but also split friction, that is one track has more grip than the other.
The GRY uses Torsen both front and rear. If you know how they work, skip this part and go to the next paragraph. This vid
unfortunately doesn’t really explain Torsen to the end, but do watch it. Recap, trying to put it simply, it uses the principle of a wormwheel, I assume you all at some point played with one with Lego Technic or similar. If you then rotate (=powering with your fingers) the worm, it rotates the normal toothed gear (slowly), the other way nothing happens, it locks. Torsen is not as black/white but in the analogy the worm is on the crown gear side powered by the engine. So when the wheel end applies torque (because it has most grip) to the other less grippy wheel, it wont activate the differential, i.e it locks. If both wheels have the same grip and thus transfer the same power, it is the differential that powers the wheels and it acts as an open differential. Makes sense? There is a problem though, if one axle has zero grip, then there is no torque in the system and it acts as an open differential. So the torque the grippier wheel can transfer is actually dependent on the torque the less grippier side introduces in the system. With Torsen one then talks about a multiplier, the grippier wheel can transfer e.g. 2,5 times more torque than the less grippier one. Interesting is that this is insensitive to differences in rotation speeds, it truly is a torque sensing thing that works always, immediate and without any delay.
Now having a grasp of Torsen, we understand that it works instantly and isn’t rely on differences in rotation speeds. It is always there, always working, no reaction time, no calibrations. It’s a differential that actually puts the power down. But it needs to have all the wheels on the ground and in that sense its working is integral with the suspension system and its development. If a wheel does lift or has zero grip and spins out, traction control can still brake that wheel to activate the torsen. Or left foot brake…
Torsen isn’t active in the sense that an ecu can choose where to put power down actively, but torsen is very intuitive and ’natural’ in its responses – you don’t notice it in a good way.
Other systems:
- Plated lsd. Depends on speed difference to lock an open differential. Can be finetuned for amount of locking both in acceleration and braking. Great for finetuning a certain application, e.g. trackwork, less so for wide application. Maintenance sensitive. Not dependant on having both wheels on the ground, but dependant on a certain wheel slip to lock. Therefore still passive. Mostly aftermarket.
- Electronically controlled mechanical lsd. Open differential with plated clutch. Locking fully controlled by electronics. Great flexibility but dependant on calibrations and also some reaction time. Passive. M-differential, VAQ.
- Torque vectoring differential. Variation of the above, open differential and seperate clutches that engage and force upon the axles a separate fixed gear ratio, forcing the outer wheel to turn faster and therefore actively inducing torque to the outer wheel. Also called yaw control (Evo) as it can actively change the cars yaw and attitude in a bend. Sport differential on Audi.
- Twin clutch with torque vectoring. No differential, just each wheel with its own clutch and geared higher than the front, allowing for torque vectoring or yaw control. May overheat. FRS mk3
- (edited) A45s and Golf 8R: new system, doesn't have a differential and is using clutches only for each rear drive axle. , it looks like it using clutches on each side to engage a variable gear ratio on each side of some sort, which should negate the overheating issue as the clutches probably aren't slipping all the time. Should also allow for overspeeding rear axle. Smart. No overspeeding means that torque vectoring isn't actively creating a torque response from one wheel (no active pushing), making the system more subtle and more reliant on grip loss to get moving. Perhaps less interesting dynamically?
- Brake based torque vectoring: braking the spinning wheel without grip on an open differential, transfers the same torque applied to the grippy wheel. Not very intuitive/fluid, very calibration dependent and saps power, so more for mobility than for power distrubution.
Yaw control/torque vectoring is a bit controversial as it is by definition a computer actively steering the car. Sometimes disliked as artificial, others love it (Evo). And then there is the front end differential which can be open, or lsd of some type. Making them gel together isn’t always the easiest either. As soon as there are two or more active systems fore/aft and left/right, the amount of calibration variables goes through the roof once all possible handling situations, making it harder to make the car feel intuitive and natural in its reactions, which is what good handling is about, right?
Concluding
I like the GR Yaris system on a theoretical level, active in that it involves the rear axle if one wishes, but laterally very intuitive power distribution. Relatively simple and light. An elegant solution which should be easy to set up to work well in a wide range of handling situations. And from the testdrives of many, it is lovely in real life also.
Thank you @Onehp for this as usual very good write up. Not sure if it is the right spot; if not, @Admin feel free to move my post to the appropriate Thread.
I could experience lately what Evos with studded tyres can do on snow & ice and I was just blown away. The AYC in these cars is brillant. We went sideways for 2 days and after returning to work, my team said I never came back with such a smile in my face.
As buying an Evo is not an option, I am thinking what can be done to the GRY to get closer to the Evos and am thinking of a 1.5 Way clutch type LSD (i.e. Drexler, Cusco) for the rear. To date, I only had Torsens in my cars.
Has anyone experience with clutch type LSDs he could share here? Perhaps an old Evo owner owning a GRY (circuit pack) today?
Snow and ice, good studded tyres, track 50:50 and some added front camber makes it perfect imho, can just turn and trottle into a bend and hold it there easily
. Imho better then AYC as its natural.
However as grip levels rise, the rear torsen disappoints if attempting big skids as it can loose traction with the smallest lift of the rear inner wheel. I had skipped the friction modifier in the rear diff oil, that reduced the instances of loosing rear traction by increasing the Torsen locking factor by, iirc numbers from Torsen, 20% which is quite a big deal. Another part in this is to learn left foot braking instead of throttle lift in a skid, that helps torsen keep stability and equalise wheel speed.
Next step if still not happy is indeed a plated rear LSD to seal the traction. Not sure about how much locking one wants on lift, basically would haave to try or find someone with the right experience on the platform. Mobility vs stability vs skiddability on trail brake.
Lastly, also a better dampened suspension that has quick extension when the wheels are unloaded - essentially rally suspension, that will seal consistency when skidding over uneven surfaces.
I never took those two last steps, for the road it's definitely overkill.
Great vid @Onehp - that‘s what I look for on Snow & Ice. 👌🏻
When going down the planted LSD route, I understand that this also helps the car turn in bends and one can go much earlier back on throttle, increasing fun in grippier situations.
Am just undecided; classical 1st world challenge. Perhaps an old Evo owner having a GRY will chip into the Thread….
Great vid @Onehp -
FYI I could do donuts in the dry on 265 drift tyres with the changed diff oil, totally impossible before, so a very cheap improvement.
There is an evo thread here somewhere but didn't find it. Jagymeister on YouTube has them both and is mostly out with the GRY on rally drives and his car is mostly stock. So while material matters, with some small tweaks and driver training you can get very far already....
lfb to get car getting rotated helps alot, one car know's where its going you can continue with throttle.
Thanks - will definitly try! 👍
