It won't be idling on -2.7R camber anymoreLuckily the rear is more or less idling in this car so As @Onehp said rotating helps alot.
I'm likely going for -2.8F and -2.5R for camber. Maybe it is an improvement to as is.
At least, the tire on first photo (with the dogo
I do have a per-side 2mm (12' = 0.2°) toe in on rear. It did not produce any unever wear with factory -2R rear camber. After setting -2.7R I am having this wear.
