GR Yaris gr yaris handbrake drift modification solution
shoeihsieh
taiwan
I try to modify my handbrake easily with previous experience
In this way, when the handbrake needs to be pulled in rally occasions, there is no need to keep pressing the release button.
How secure is it? You don't want the handbrake to accidentily lock when you don't expect it, can easily cause an accident.
Nutron has a ready solution with very clear mode, pin secured = without ratchet.
I have removed ratchet function altogether so there is no possible confusion and can always quickly grab the handbrake as a 'handling option'. Parking in gear...
Don't worry, he's very safe
Such device transformation has existed since EG6, GC8, and S13 more than 10 years ago
I still use these vehicles
It's even fine for a game
Regarding the products you share, the principle is the same
It's just that I don't think he's worth the price
Instead of spending the same money, it is better to choose a more professional hydraulic handbrake system
And my transformation is in line with the convenience of daily use
I guess it's fine if you assume the ratchet always could be active.
This is my setup, I always know the ratchet isn't working and as such can always use it. It can block rear wheels at 100km/h in the dry so no need for hydraulic...
I guess it's fine if you assume the rather always could be active.
This is my setup, I always know the rachet isn't working and as such can always use it. It can block rear wheels at 100km/h in the dry so no need for hydraulic...
-Purpose-built cockpit (y)
I've ordered a similar steering wheel spacer but (looking at yours) I'm also drooling for the gear-shifter "riser" - did you bought it from somewhere? Or is it "custom"? Cheers
Cheers, it's custom. Similar effect with higher gear knob from the GR86 (not sure, double check)
OK, I see... wouldn't you have any of these that you like to sell? :giggle:
(I would prefer to keep the GRY knob - over the GRC, trying to keep a more oem interior... alternatively I may consider the GRMN one)
BTW: really like the CAE shifter but I don't trust myself (or someone else) driving my car to get into "right-gear"/everytime... 😬
Hi, what brand ebrake button is the one you installed? I want to do this to my GRC.
Perfect, thank you! Is it possible for you to provide a step by step on how to install? Kind of confused when watching your video.
Do you know how to disassemble the OEM's hand brake system??
As for the subsequent parts production, I have improved some ways, it will be more durable and strong, I can take good photos and upload。
Yeah, if you can do that it would be of good help!
