GR Yaris 'Loose' Sump Plug
n0m0re0il
Hi,
Was hoping for some advice. Maybe others have been in the same situation.
My GRY was in for it's 2nd service at Toyota main dealer in December. Under 10k miles, I've had it since new (1st new car, dream car), planned to keep it a long time if I could.
Car is now in garage because it turns out the sump plug was not correctly tightened, plug backed off and car dropped all its oil.
How long it's been badly leaking is unclear. I've not done much miles at all since service. Car was turned off when the low pressure oil warning came up on dashboard and I was luckily in a car park. Underside of car soaking with oil. It didn't sound great by the time I realised what was happening...
I feel a bit sick to be honest. Car was recovered to dealer and is sitting there waiting for the verdict.
The way I see it is they will either just chuck more oil in it and cross fingers if it sounds ok, or its toast and will need a new engine? I can't see a scenario where I will be happy with the outcome.
Any advise on what I should be asking for here, or how to proceed? I'm so angry, only used the dealer to keep the warranty as safe as possible, wish I'd taken the gamble not to now and used my local garage.
Thanks
I had the same with my Evo 9. A certain dealer in Sandycroft that sounds like Ballbaghers serviced it and 2 days later it dropped all its oil on the M56. Apparently the junior(!) mechanic forgot to tighten the sump plug properly. They refused a new engine but "checked it over and it seems fine". Luckily it was as I drove it for several more years without issue.
I was advised to not accept any refund of the service or anything from them if there's a chance I'd be pursuing this legally, unfortunately I'd already accepted the service refund by this point. They did that immediately, almost like they knew what they were doing and why!
Have you accepted a refund? Maybe it doesn't matter but hopefully someone comes along with good advice.
Sorry to hear your woes! Terrible situation to be in.
In a situation like this, the first thing I would do is cut the oil filter and have a look. No metal generally ok. Ifs the filter is full of bearing material then your crank is US.
Thanks for the feedback. As expected, they want to just fill it up and hand it back. I don't think I have a choice apart from I asked that Toyota UK were informed to make sure they would still honour the warranty should anything related come up in future... Watch this space.
You should contact Toyota about this!! Don't rely on them wuckfits to do it, they can't even tighten a sump plug properly.
Fire an email to as many Toyota addresses as you can find explaining the situation and how you're concerned about damage and future warranty. I wouldn't start asking them for a new engine as Toyota aren't likely to pay for dealers mistake, but just get them to confirm it's recorded for any future warranty claim. If Toyota in future do have to provide an engine in warranty then I'm sure they'd like to know about this so they know where to send the bill!
Then maybe contact Citizens Advice.. Your call.
Don’t leave it with them. Take to a decent independent specialist and have them cut open the filter and take the sump off. That’s the only way to check, anything else is just risk of a time bomb that you can’t hear ticking. Also check the parts used for the service, I suspect that many are not replacing the crush washer and even if torqued up they can come loose.
I would leave independents out but require Toyota to do proper analysis with documentation. Othervise they can say someone else messed it and its not their problem.
@n0m0re0il I understand why you might not want to name them, but could you give a rough area of the country they're in to hopefully put some of our minds at ease?
The issue with this is they will just dispose of the old filter, fit a new one, fill with oil and give it back saying it’s fine.
They have offered next 2 services free, new undertray and coded in my winter wheels. I also have email stating what happened from dealer and they have raised case with Toyota UK. I will probably take an oil sample once I put some miles on and get it checked. My gut says car is fine but situation is not ideal.
