tonic
- Aug 31, 2023
- 217
- 702
While planning a trip to Sweden for some ice driving, I decided to build rear bumper corner support brackets. These are to prevent the rear bumper from getting ripped off if I catch a snowbank with the rear arch. A fellow of mine had this happen, and it resulted in his rear bumper breaking in half.
There are some options available on the market (like https://www.ebay.com/itm/276479589698), but they may interfere with rear mud guards. Plus, I’m not a fan of attaching them to the main rear subframe mounting studs.
Tried to stick to the following design requirements:
must allow rear mud guards to fit;
needs to be stiff under pulling action, such as when the bumper is pulled back by a snowbank;
should be collapsible in case of a rear impact;
must be minimally noticeable, want to keep my GRY looking stock, even from underneath
should be reasonably easy to manufacture.
Here’s the solution I came up with over the weekend:
The retaining piece mounted on the outside of the bumper fits completely under the rear reflector.
These will be made from metal once I finalize the details, with the piece under the reflector printed from ASA.
The goal isn’t to create a rock-solid solution that keeps the bumper in place no matter what, but rather to improve corner rigidity. From what I can tell, even with the flimsy plastic pieces in place, it already makes a significant improvement.
Feel free to share any ideas on how to make them better, why they might not work, or anything else that comes to mind.
