JohnCassidy
- Sep 23, 2024
- 21
- 25
Hi,
this is my first post on this forum. I want to warn all of you
TLDR: Do not buy DBA brake discs if you plan to drive the GR Yaris in a sporty/spirited way.
I am regularly using the GR Yaris in various types of track day events. At the moment, I have taken
part in over 15 events with this car. I would rather describe myself as an average, cautious driver.
Recently, I worn out the second set of the OEM discs. I decided to buy something from another
brand. ATM DBA T3 5000 set was easily available. I put the discs on and carried out the brake pad
bedding procedure in accordance with the manufacturer's recommendations (Ferodo DS Uno). I
went to a track day. In total, I drove about 200 km (~125 miles) on the track and 800 km (~500 miles) on the highway.
During the event, there was no "soft pedal" phenomenon, the pads did not show excessive signs of wear, no
brake fluid loss, no loss of braking force. In a word, everything was normal. I did not overheat the
brake system.
When I got home, I saw an image like in the picture attached. Rotors for quite a lot of
money only good for the bin. Of course, I filed a warranty. Unfortunately, the EU distributor
showed a lack of technical knowledge, and the manufacturer based his refusal on something like
"you bedded the pads wrongly and overheated the rotors, and by the way, you shouldn't use this
product for track driving". This contradicts the statement that the DBA T3 5000 are discs
recommended for track day events (https://dba.com.au/products/brake-rotors/5000-series/).
The manufacturer and distributor do not want to listen to any arguments. They do not
reply to any messages.
Don't make the same mistake as I did, and don't buy this product. It is
obviously far below the quality of the OEM brake discs.
brake system.
