GR86 GR86 service / warranty
Anchor93
Fascinated Member
I would appreciate some clarification on the Toyota warranty please, my recently acquired car, GR86, is just about 1 year old, done just over 8k miles, what are the rules about using an independent company for service rather than Toyota main dealer? Reason for my question is the response from the independent when asked about service and possible impact on the warranty is as follows :
We absolutley carry out this type of service as for warranty it should not affect your base warranty with Toyota however you will miss out on the toyota relax warranty of ten years/ 100,000 miles.
Many thanks
Mike
You can have the first 3 years done at an independent garage as long as they are vat registered, follow the Toyota service schedule and use official parts.
After that you are on your own.
Thanks for that, if after the 3 years you go to Toyota, do you then qualify for the 10 years etc
I used an independent JDM specialist for my yr1 service (int) and am booked in with the same for my yr2 (full).
The initial Toyota Warranty will cover me only up until the car reaches its 3rd birthday, but if I have the yr3 service done by Toyota, I get an additional year’s Warranty (covering the 4th year). Each subsequent annual Toyota service will result in an additional 12m warranty from the date of each service, up until it’s 10.
If the car is serviced independently outside of the dealership network, Toyota won’t honour any Warranty after the car is 3 years old. That said, you could risk independent servicing every other year, or for a few extra years, and return to Toyota several years down the line and still get the 12m rolling warranty cover…
