leman
Fascinated Member
Just to introduce myself, GR Yaris 21 plate car owner for 8 months, took 3years to convince the wife its what we needed
The GR Yaris had 22k and full Toyota Service history OE tyres and brakes pads, previous owner did state no track days and I had no reason to not believe it.
It's been a lot of fun but I am having some constant niggles that are gradually getting worse to the point of contemplating selling, I don’t want to accept that this is the way Toyota envisaged the GR Yaris.
Please excuse my long first post and very poor grammar.
Issues below.
1: Absolutely diabolical gear change when driving around town 1st-2nd sometimes 2nd-3rd not as bad when driving spiritedly.
2: Backlash noise in drivetrain akin to a worn out 1990 MX5 (yes I have one)
3: Feels like the engine is literally bouncing around the engine bay when giving it beans, so much that it upsets the cars handling down bumpy b roads
4: unpredictable at high speed (autobahn obviously) Solved as the rear was toeing out from the factory I even contacted the previous owner in case he had had it set up like that (his answer to that sort of reinforced my belief he had done no track days)
5: Braking very poor not and what I was expecting, pads 50%worn. Solved by fitting new pads as upon inspection clearly the pads had been sticking to the disc after his washing regime and pulled off big chunks from the friction surface, Immense brakes now, if only I could stop those dam hazards under braking!
So to try and cure the remaining niggles I firstly changed my driving style to try and work with the car, I reset the gear linkage numerous times, this was always better but would soon return to be problematic.
The last linkage reset I marked the threaded bar section and lo and behold when I checked the cable had moved.
As I first thought too much movement in the engine mounts pulling on the cables and blocking gears.
I succumbed to purchasing the Black power Flex insert and fitted it on my Standard torque mount which incidentally is split (I am in the minority here that I believe the torque mount is faulty where it splits)
So the Power Flex insert as many have described is magic, Cigar in hand moment!
The backlash noise has gone completely I have sweet gear changes and the engine feels more locked in, an absolute game changer as they say.
This got me thinking about what am I actually masking with this insert so I removed it after one day to re evaluate.
Straight away all my gripes were back, so I needed to investigate more, I borrowed a borescope from a work colleague and unfortunately I found the O/S/F engine mount is not in a good way, cracked In numerous places and the top split goes full circumference if you jack up the engine the mount separates.
Sort of explains my issues I think?
It's a 21 plate car with the 5 year warranty so hopefully getting the two mounts changed will transform the car.
I have asked them to replace all three mounts as surely the gearbox mount would have been compromised and taken more load than designed for.
Has any one seen this problem yet?
Regards Leman
Issues below.
Regards Leman
