GR86 Secure dashcam cables in headliner across top of windscreen
MorrisM
The gap at the front end of the headliner Is quite big so my cable keeps slipping out of the headliner at the top of the windscreen after a few miles of travel. Any tips on how to keep these in - I’ve used small pieces of black card as wedges on another vehicle so will do that again unless there’s a better solution? Thanks.
How about cut a slit in one side of a rubber grommet and put the grommet around the cable(s). Or a zip tie?
The gap is pretty wide (I have the same issue) and the recent warm (ish) weather appears to have exacerbated the problem but I haven't got around to finding a solution.
GearFX's suggestion seems something to try though.
