Yeah, it was just weird that this message seemed to randomly pop up a couple of times.As above, that's in the settings menu to en/disable the active headlight function.
Bit bizarre that it would pop-up by itself.
You've not had any other funnies with the touchscreen doing its own thing?
I don't think there's any way this is a headlight fault - an issue with the SRH would come up on the dash, and not the settings message you're seeing on the headunit.Yeah, it was just weird that this message seemed to randomly pop up a couple of times.
Everything else normal. Lights are always on auto. I’ll ask dealer to check that all is well at 1st service next month.
I’ll maybe not fit that headlight PPF in case something is up with the lights- that’d be a pricey one if a dealer had an excuse to walk away from a warranty claim![]()
It's this. I would like to turn off the speech button on the wheel as I have no need of it but often when I go around left hand junctions I clip the button.I want to note that I'll randomly get the car settings dialog pop up too without my input.
My assumption is since the shortcut is in the top/left corner it might be getting an accidental press from flex or a not properly applied touch panel.
