GR Yaris Track mods for a daily driver?
Altocumulus
Hi all, I've had my 2021 GRY Circuit Pack for a few months and I'm still loving it. I've occasionally driven it very hard on quiet B roads (where it has impressed) and I've done a single track day.
I've done many track days in previous cars (medium-fast group), however I felt a little let down by the stock GRY's track abilities. I know road circuits are not the stock car's favourite or intended environment. The two main areas I felt it was deficient were seating and lack of negative camber. Unlike many others I really like the stock seats (this is a daily driver, and I'm short).
So, I have ordered:
- Schroth quick fit pro harness
- front camber bolts
- spare set of BBS wheels with track rubber (RE71rs) [I really wanted a spare wheel to take on longer road trips, so bought a whole spare set to double up for track duties].
As a daily driven car, I'd really like to know what other modifications peeps think are valuable. I'm fully aware that many aftermarket options exist, but I'd like to keep some of the daily driven 'sensibilities' intact, rather than turn it into a full time attack weapon.
Any advice would be appreciated.
Off the top of my head if you are doing multiple laps:
Brake fluid
Brake pads
Pad shims
Oil cooler
0.5L extra engine oil
Cold air intake
Strut braces (maybe)
Engine mount stiffeners
The usual tyre pressure gauge, some chalk to mark tyres... i question the choice of the RE71s, people I know here weren't impressed but perhaps that was higher track temps in Oz. Which harness?
I agree with Humpty đŸ‘† not a lot is needed really. Brakes and engine oil will be first to overheat, in my admittedly limited experience.
The brakes are pretty immense so no need to 'upgrade' them with new calipers or anything, just fluid and some decent shims should see you right. Maybe better pads too but see how you go with simple things first.
Before fitting my oil cooler my oil was hitting 136c after a few laps of Anglesey. Since fitting the cooler the highest I've seen is 120c recently at Aintree and Blyton Park, but that was after many many laps and I needed to come off for a drink and a rest by that point, so I'm absolutely fine with that.
Adding on to the other mods mentioned above, I personally disliked the amount of body roll, so I got coilovers with a stiffer spring rate.
Apart from the aesthetics of a lowered car, the car felt amazing in corners with much less body roll.
YMMV since some people get used to the body roll, but I wasn't a fan
is that a Circuit Pack (or "rally" version) or convenience/pov pack?? - That are noticeable differences between - susp wise.
(I find my own CP already border-limit stiff for daily driving)
Yes, part of the reason I feel I need a harness is because of the body roll (plus standard seats).
Brake fluid
Brake pads
Pad shims
Oil cooler
Cold air intake
I'm in Oz (Vic) but haven't yet done any hot track days with the GRY. I have experienced the ecu pulling timing/power in hot weather on the road due to heat soak.
I haven't had an issue with brake performance over 6 or so laps during a typical track day session, but I've not yet run it in summer on the track either. I've read some discussion on brake pad shims, not something I'd seriously considered until now (on my list to look into).
What tyres are you running in warmer weather? Others I've considered are A052 or CRS. I'm a bit reluctant to go full semi slick with standard suspension/arms, but keen to hear from others on this.
I do track days in mine and also compete in sprints and hill climbs with it. Have done a few mods and am quite happy with the way it performs on track but it is a bit hard on the road.
Mods:
KW Clubsport V4 coilovers
Camber bolts front and rear
Front strut brace
Motul 600 brake fluid
Carbon pad shims
HEL brake lines
Powerflex gearbox mount
Schroth 3 point harness
I have a circuit pack/Rally. If I remember right, the main difference between our Rally and the 'Standard' was a thicker front ARB, and a higher compression/rebound rate for the shocks.
I think spring rate was the same for both at around 3.5kg. FWIW, I ended up getting 8kg front and rear - a lot stiffer, but I still have the compression/rebound relatively soft in comparison.
Taking it for a spirited drive on an overly bumpy road wasn't particularly enjoyable, but it's fine for grocery-getting/commuting and great for track. It's still good for sprited drives on flat roads or roads with a steady elevation change, just large amounts of bumps aren't great.
@Altocumulus something I forgot to add - you might also like a short shifter. I got myself a Forge short shifter and made shifting feel great with the shorter throws. Naturally, you need a bit more force to shift, but I got used to it
For me I run custom MCA reds. Camber is -3 up front and stock roughly -2 at the back end, toe is +1/-1. I tried +1 at both ends and it was too taily on the road and wandered like a drunk peripatetic pilgrim. Semi slicks on the factory rims for the sprints, R888R for two seasons until they weren't legal to drive to the track and now AD08R which were my daily tyres until they got really noisy at about half tread depth. Fitted V107s as dailies but these are just about done. Very liklely AD09 going on next. A052 would be an option but are stupid expensive up here for the life.
Harness is the Schroth QuickFit Pro SR18662 which is right hand side and red colour.
With regards to the RE71s I like the pattern and ran the old ones 108 years ago on my E21. I was really tempted until a guy with a WRX at the sprints told me they were crap and went off after a couple of laps. He transferred them to his JDM ute thing. Also be aware the A052 are very camber sensitive.
Brake lines yes! I forgot those. Factory arent bad at all but braided is a bee's euphemism betterer. West African bee. Be aware some EU certified products aren't considered ADR compatible. I went with Goodridge.
Thanks for all the replies.
I got the front camber bolts installed and the geometry set up this week by some pros, and I can already feel a really positive difference on the road.
I'll install the harness in the coming weeks, and have ordered some brake pad shims.
I'm looking forward to the next track session!
