Since i get asked nearly on a daily basis, what tire and wheel sizes i use and recommend for daily or track use, i decided to make a little guide with what fits, what not and what i recommend for daily and track use.
This sheet is for information purposes only. It is NOT a guarantee that every wheel/tire combination will fit or is even street legal!!!
Some combinations need a specific amount of camber to fit.
It should be clear, that with wide wheels/tires, you will run into certain problems with the wheel touching the fender or the damper, so you need to adjust camber accordingly.
