GR Yaris Misha just gave us all a present!
Norbi
Bolzano, South Tyrol, Italy
This is hilarious: a pimped E46, supposedly with 480 hp on the wheel (sure…), with Misha piloting it. And 2 GR’s just flying by:
There is also the parallel video on that situation of the Yaris owner, very interesting how much extra weight he had on board:
A true blessing to the (pretty unmodified!) GR Yaris from the master of the Nürburgring himself!
Thanks, Misha! You’re the best. Well, together with that other guy now…
PS: here’s the short:
Now the Engine is dead, 1. Zyl. is broken, not EcuTek tune Engine.
Bad Tuner :mad:
Grey or White one?
What was the race track factor again in terms of wear and tear? I think x20 or something? A lot of people always forget that the strain on a race track is so much higher than on the road. And the grey one has over 10,000km on the Nordschleife alone. Still bitter and sorry to hear:(.
The grey is a beauty👍🏻.
Bad Tuner :mad:
Grey one then as the white one isn't tuned. There is a pattern emerging?
You know it's tuner related? Bad injection control? We have quite a few cyl 1 failures now, should make a list and search common denominator...
There's a noticeable shift in tone when Misha goes from 3rd to 5th gear and applies WOT. It resembles a 'chopper' or rattling sound, quite distinct from normal engine tone. It doesn't seem linked to cornering forces and diminishes notably when going downhill (indicating lower engine load). The issue appears non-existant after fixing the 4th gear. This may be some mechanical noise or ANC artifact. Or could it be LSPI?
It could be clearly heard at the end of 1st lap roughly between 12:30 and 12:45 of the video, although tone changes are present throughout the entirety of the first lap. The tone difference is quite noticeable in waveform as well.
normal tone:
'rattling'
I thought the patter was already quite clear… people don’t know how to tune this engine well -keeping some reliability at least especially with track use-. Let’s see with Ecutek that AFAIK have the possibility to access a good few more control tables but not all of them.
Don't see track driving any more challenging as doing WOT runs on motorway, outside giving engine more g-loads due to corners and braking so it is more of a challenge in terms of lubrication system. But bad tune will be bad on track and on road, and vice versa.
With a well setup chassis and sticky tyres the lubrication will be even more of a challenge due to increased g-loads.
I would add heat soak to that.
Correct, and I would add that heat load is actually very different. Even on autobahn, you're not WOT all the time and if you are, you are near top speed and get loads of cooling due to the speed. On track there is only cooling on WOT as there is only WOT (if driven well). Off throttle there is no air flow through the engine, not the IC, and speed is scrubbed very quickly on braking. Everything gets hotter, and all metal gets weaker. If tuning, higher loads means there are less fatique cycles before failure, compound made worse by the heat of tracking. All metal fatigues and ultimately fail, it's just with well dimensioned parts this happens well past the general service life of the engine... There, I just explained something pretty basic really that a LOT of people messing with engines don't seem to understand....
Track is quite similar as fast road, depending of course definition of fas and what track is driven. But if car is btw 80-160kmh there should be enough of cooling. having a bad tune or poor cooling is bad idea for either.
Ok we disagree, I have trouble getting oil temps above 100C in winter and in summer don't go above 110C, and I think I drive a pretty hard fast road at low speeds (very small roads) that don't help cooling. Maybe other fast road users think they need an oil cooler but have not seen examples other then obviously very hot climates...
If you use less throttle it produces less heat. No matter where you drive
Michael, I'm afraid I have to disagree with you, but it's not that bad, is it?
Track use is much more stressful than fast road driving. I can explain that simply by the fact that I don't completely wear out a brake in one day on the road. My Evo used around 32-45 liters(yes 45l) of fuel on the race track, you'll never manage that on the road. At least in Germany you can't put anywhere near as much strain on the car as you do on the race track. Maybe just for a short time, yes.
I'd never let him drive one of my cars. Issues can always occur but why let someone rag on your pride and joy so they can gain exposure themselves?
Wholeheartedly agree. He is a quick driver but the overtaking risks he takes are daft at a place such as that. Doesn’t matter how good you are, if you’re around other drivers who may not be as experienced and might make mistakes then it’s just not worth it.
But easy to compare amount of time spend on WOT. Autobahn can also be bad for car if internals are not up for the requirement
