ctecperformance
Devoted member
- Nov 1, 2023
- 96
- 170
Another update on the C-TEC Performance front pipe back system for the GR86.
We've recently completed three installs. Each owner was able to get a close up inspection of their system prior to the install. It's also a great opportunity for us to answer any final questions, plus it gives us the chance to explain in detail why we've gone with the design we have, point out specifics which will be unique to our system, discuss the benefits of V band etc.
The customer then gets to see the full install process. The ease of install, the accuracy of the fitment to the OEM front pipe flange, accuracy re alignment to the OEM exhaust hanger points and the perfect alignment between the two sections of our systems at the V band connection. A final sign off from each customer on the tail pipe alignment, then it's engine start up time.
We do check whether ASC is still active, and if so we strongly recommend this is disabled. We can do this at the point of install, it's very straightforward, and fully reversible.
We've requested each owner has a period of time with their new system. We welcome all feedback, and once all parties are entirely satisfied, that's when we will officially roll out on this forum.
