GR Yaris Whiteline lowering spring kit
gazYar
Hi all,
So guess it's time to lower my GR. As opposed to doing the full whack (coilovers, corner weight, etc) thinking of starting off with lowering spring kit.
Eibachs seem the popular route 25mm drop and the fronts minimal difference to stock(based on feedback of owners). H&R owners 35mm? owners sayr great on track but perhaps a harsher ride on everyday UK roads.
Just to add a spanner in the works, I'd like to know if anyone tried White line lowering springs? 25mm drop no different to Eibachs.
This kit contains 3.3kg/mm (185lb/in) front rated springs that provide a 25mm drop while the 2.9kg/mm (162lb/in) rated rears deliver a desirable 25mm to the vehicle.
They seem to have a good rep with their caster bushing kit, ARBs, etc. And been told Down Under better quality vs. Kings lowering springs (used by Suspension Secrets)
Hope some suspension / geometry experts out there can shed some light on the White line specs? Any info is greatly appreciated !
Ta
Forgot to mention, so purpose is to lower the car 25mm fast road use. Not too harsh for everyday use and the occasional track day.
My Eibachs have a 25-30cm drop both ends and are not harsh.
Any idea with re: Eibach Pro kit what the spring rates are?
