- Jan 4, 2023
- 15
- 8
- 3
TRACTIVE FULL ADAPTIVE SUSPENSION KIT + DNA TOP MOUNTS!
Selling a full Tractive GR Yaris specific adaptive suspension kit with DNA Top mounts.
This is everything that you need, as has just been removed, fully working from my car today, 8th Oct 25.
Everything you require to install the kit is included. It’s considered semi-active
The wiring harness isn’t too complicated.
Most of it sits under the driver's seat and runs down from the rear (where power is required) along the interior floor trim to the driver's area.
The display comes in its own GR vent; it’s actually a CanChecked display customised.
It's specifically sprung and custom valved for the GR.
Includes a set of DNA top mounts, which gives you additional camber or caster adjustment and a more solid top mount.
A great bit of kit - you can go from fully soft to fully hard at the touch of a button
Great on track and great on the B-roads, where it's super compliant.
I have had it for just over a year or so, about 5000 miles, and 2 track days. No complaints.
In great condition IMHO, only 2 minors, a small amount of corrosion on lower front threads (not where the lock nut is), and one damper shaft cover on the front needs to be pushed back in place, that's it.
Good range of height adjustment to suit your preference and you can configure 5 custom suspension settings ready on the display.
Kit retails for ~ £5000 with wiring & display, with the DNA top mounts ~ £500, so in total about £5500
Questions, etc, please message.
Looking for around £2800, open to reasonable offers maybe
Ideally would like a collection and am happy to meet. I am based London/Surrey, but happy to drive.
Cheers.
Product Blurb...
This TracTive standalone system makes adjustments for you based on g-force input. It’s controlled through a mounted controller and can be adjusted via touchscreen which has 5 saveable presets. You can also adjust front and rear axle damping individually and the system responds with adjustments within 6-10milliseconds.
What makes it unique is the adjustments you can do for anti-roll and anti-pitch control. The system controls unwanted body movement when it’s needed the most.
The front dampers are inverted and utilise a 38mm piston to maximise stiffness and we use the stock top mounts for ease of installation. We’ve built in camber adjustment on the lower bracket to allow fine tuning of the alignment.
The rear shocks are full alloy body with a 46mm piston. The rear spring sits on the original position with a height adjuster.
The kit allows you to drop or raise the car with lowering of 30mm front and rear maximum. Raising the car is set to a maximum of 10mm above stock height.
Cheers.
Product Blurb...
