GR Yaris Removing PPF
Neveragain
What's the best way of removing these small PPF sections at the bottom of the wheel arch, always look dirty on the edges after a clean.
A hairdryer on max heat , not too close and just peel.
Don’t just tear it off backwards as it can take the paint with it. Get it started and pull so it lifts away on its own when it stretches.
Red line is bodywork Black line is the tape.
Thanks, also seen a lot of posts where people use boiling water, which they say is safer.
Yes that is another way but you need a lot of it to keep the tape hot though. A hairdryer doesn’t get hot enough to damage the paint. It doesn’t danage haur. Yes a heat gun will though.
