New member, stock (for now) gen 1 GR Yaris CP
boiNXTdoor
2
2
3
Hi all! I've recently taken an interest in modifying my GR Yaris. I also been lurking the forums for a while so I figured I should at least say hi lol.
In the following month, I intend to:
-Add Powerflex Yellow upper engine and transmission inserts.
-Add Collins Performance CP Torque mount.
This will be my first mod. Please, feel free to chime in if you know a better alternative and/or combination for Torque mount/transmission/engine inserts
In the near future:
-Change alignment (using Powerflex camber bolts -front and read-). I find this subject quite complex and I definitely would appreciate some input. The idea is to retain the stock suspension and tire size as I don't intend to track the car. If you're on stock suspension and rims feel free to share me your alignment setup.
In the future:
-IC Spray retrofit. Mostly because it is cool as hell. Usure if I will do a completely original retrofit and run a pipe through the car or just connect a T valve to the windshield water jet and use gardening atomizers to the same effect.
-Exhaust w/gpf delete.
-Intake.
Feel free to comment/critique my planned mods. Have a nice day!
In the near future:
In the future:
-Intake.
congrats for new GR! cool idea with that windshield water system but the reservoir is ridiculously small so you'll run out of juice in no time.
for camber I'd start from -2.5' front and -2' rear and then iterate from there based on your liking.
Reactions: boiNXTdoor
