GR Yaris Michelin Cross Climate 2 , Tyre Pressure
CB2007
Surrey
Fitting a set of winter wheels with the above tyres, any suggestion for correct tyre pressures
Had mine a month and finding std pressures are fine.
I was thinking maybe +2 psi or so for slightly softer sidewall which I was using on winters but I did
contact Michelin and they said they are designed to run on std pressures and so far I’m finding them very good.
Since the weather has started to get colder, I have a guessing game each time I drive my car. What tyre will trigger a warning light and will it be front and rear. My NSR kept flagging up as under inflated so I just gave it puff of air, now it's recording higher than OSR. My drive mode is Track. My only complaint about my car since I got the car 30/06/22
If garaged, need to add 2-3 psi to recommended pressures if around or below freezing (as they will settle correctly then). If car lives outside, add pressure to recommended pressures before driving a longer distance.
Just reset the tyre pressure warning and it will accept the pressures you have as normal. But I suggest you do the above.
I've run CC2s on the Yaris for a year now, been using 2.2 Front and 2.0 rear (approx 32/30psi). They've worn evenly and been a brilliant all rounder, as I'm no track warrior!
I had CC2's on last year (putting them back on today for this winter) and ran the standard pressures, which seemed fine to me. As RichP says, even wear and I'm not 'crazy' either!
